My 2013 G37x Build
Old Sep 16, 2020 | 02:49 AM
pjmjr508's Avatar
pjmjr508
My 2013 G37x Build
Current list of what has been done to it so far;
•Ksport Coilovers (Current GTF is 26.50" F&R)
•SPC Rear Adjustable Camber & Toe bar (Spring bucket delete)
•SPC Adjustable front UCA
•Hotchkis Front & Rear Sway bars & adjustable sway bar end links
•Stillen Grounding Wire Kit
•Megan Front Upper Strut Bar
•ISR Performance Silicone Air Intake Tubes
•AFE PRO Drop in filters
•EBC Slotted Rotors with Red Stuff Pads along with SS Braided Brake Lines F&R, along with new Dot 4 fluid to flush the brake system
•TWB Aluminum Under Tray BLACK
• M1 Oil & filter along with front & rear diffs
• Diode Dynamics rear turn signal mod
• 5% limo tint all around
• Sport front bumper
• Kinetix HFC
• Full Stillen CBE
• 18" Sport Coupe OEM Wheels with POTENZA RE980AS tires
• Stillen SETRAB OIL COOLER KIT [RACE]
• Mishimoto Oil catch can system
• SPL PRO Solid Differential Bushing Set.
• Bell Raceworks Differential Cover Brace.
Still a work in progress
Old Sep 16, 2020 | 06:24 AM
ngolbuff's Avatar
ngolbuff
Good looking list of mods. How do you like the Ksports? Those are what I am leaning towards when I get to that project
Old Sep 16, 2020 | 11:15 AM
pjmjr508's Avatar
pjmjr508
I like them. The adjustability is great.
Old Sep 18, 2020 | 08:22 PM
ngolbuff's Avatar
ngolbuff
Talking adjustability, did you find a way to route the adjustments up behind the rear seats or what did you do?
Old Sep 18, 2020 | 08:56 PM
pjmjr508's Avatar
pjmjr508
Haven't done it myself yet, but was told what needs to be done is this.
remove the back seat.
Remove the rear coilovers.
where the rear coilovers mount to the body you drill a hole straight up & that is where the extended damper **** is to go thru to adjust the rears.
Obviously put everything back together too. Haven't done it myself yet, but this is what I was told is what needs to be done.
Old Sep 18, 2020 | 09:45 PM
ngolbuff's Avatar
ngolbuff
What adjustment level did you put the ***** at for comfort? If I find the right level right away, I wont bother with routing the adjustments
Old Sep 18, 2020 | 09:58 PM
pjmjr508's Avatar
pjmjr508
Currently I'm 8 back from max ATM.
Old Sep 20, 2020 | 09:25 AM
NYSBASIC's Avatar
NYSBASIC
Those 18" Sport Coupe OEM Wheels with POTENZA RE980AS tires" that you have mentioned on your vehicle, are the wheels 18x8 ?
Old Sep 20, 2020 | 12:53 PM
pjmjr508's Avatar
pjmjr508
Squared up
yes they are 18x8 wheels.
Old Sep 20, 2020 | 04:06 PM
NYSBASIC's Avatar
NYSBASIC
Very nice! I am planning to get those wheels also .. eventually but your car definitely looks CLEAN!
Old Sep 20, 2020 | 04:47 PM
pjmjr508's Avatar
pjmjr508
Thank you.
Old May 9, 2022 | 12:24 AM
pjmjr508's Avatar
pjmjr508
pic is on the beach in fog in ocean shores wa on june of 2021
My 2013 G37x Build
________________________________________
Updated list of what has been done to it so far; 5/8/2022
Z1 Rear Adjustable camber bars(Spring bucket delete)
Z1 Rear Adjustable toe bars
Z1 Rear adjustable track bars
Hotchkis Front & Rear Sway bars & SPL Adjustable sway bar end links
Z1 Performance Silicone Air Intake Tubes
Z1 metal coolant hose coupler replacement with vent screw (on the firewall passenger side)
Z1 Silicone upper & lower Rad hoses and over flow hoses (black)
Upgraded to Akebono calipers, pads & rotors along with SS Braided Brake Lines F&R, along with new Dot 4 fluid to flush the brake system
M1 Oil & filter along with M1 gear oil for the front & rear diffs
Full Sport front bumper with blacked out grill conversion with OEM sport lip
Sport Shift paddles
Kinetix HFC
Full Stillen CBE
Stillen Transmission oil cooler kit
Stillen Power steering oil cooler kit
SPL PRO Solid Differential Bushing with collars Set for the subframe
Bell Raceworks Differential Brace
***Currently on my garage floor waiting to be installed***
Chrome Delete Blackout Overlay Window Trim
12 volt Solutions remote start kit
Ported & Polished Upper & Lower Intake Plenum
3" Longtube CAI system wrapped in heat wrap
70mm Enlarged Throttle Bodies
ECUTEK SW with BT dongle along with LIC, just need a tuner to tun this once I install the last 3 items of what is on my garage floor list.
My Goal is to get the Stillen SC with the A2A air intercooler upgrade system
She is my weekend warrior and she is a blast
these 2 were taken 5/15/2022 @ the beach
Last edited by pjmjr508; May 15, 2022 at 05:03 PM. Reason: ​​​​​​​added 2 updated pictures
thezinfan
May 29, 2019 11:07 AM
michg37
Jul 26, 2017 11:41 AM
goldhawg
36
Apr 11, 2017 09:13 PM
rlb
Nov 12, 2010 08:02 AM
