The "4 door Z" build (4DRZ)- 13 G37S 6spd sedan
#106
That is an option I thought of that would probably work, albeit a pain in the **** since I would have to switch wheel studs for summer/winter wheels every time I switch.
You really think that would work? I am just worried that if the new bores are not completely centered they will need to be enlarged more which will cause a whole host of problems. I am going to see if a wheel shop can find narrower lugs with the right thread. Fingers crossed...
#107
Good question. I forgot to ask exactly what they had to do to get it to fit. I don't think they had to restitch anything so they may have just stretched it or got creative in how they reattached it. When I talked to Redline they made it sound like mine was an exception, so yours may fit just fine.
#109
In hindsight, are you still solid that your armrest is perforated? I was thinking the armrest ought not be perforated, unlike the shift boot. No wrong answer, I suppose.
#110
If I like the new boot, then next up will be the arm-rest. Thing is, I want it to look like yours, which is OEM perfect. So IDK if I should just order it and take it to a leather shop, or order a large-enough section of uncut Charcoal Leather from Redline, and take that to the leather shop.
I know, to each their own. But I really like the perforated look on the armrest and shift boot as it does a nice job of tying in the center of the seats. Very Feng Shui
#111
Well, I took your advice and took the wheels to a machine shop that was recommended to me by a good wheel shop in the area. The place has been around for a long time judging by one of the old presses they had that probably dates back to the industrial revolution. Should be a walk in the park for them. Fingers crossed...
#114
Picked them up yesterday from the machine shop. They tried to tell me they centered the holes off the center bore of the wheels and the lugs were not originally completely centered. So the lug bores are slightly off center from their original position. Test fit a wheel yesterday and they seem to be ok, but a bit of a snug fit. One of my techs at work is going to mount and balance them when they have time so hopefully it all works out.
blnewt (01-13-2016)
#115
So having the hub bores drilled to size was a bad idea. What do you know, the hub bores were not off center at all. The wheels vibrate like crazy now because they are not centered on the hub. So just as I feared, they just turned my rims into very expensive paperweights. It is a small shop too so they probably won't help at all with the replacement costs. Not my best day.
#116
Ouch. Then I guess props for effort means absolutely nothing. Sorry to hear this.
#117
#119
blnewt- Thanks for finding those super thin 1mm hub centric rings. I ordered a set. The machine shop is going to re-bore the lug holes and press in an aluminum sleeve so that there is no gap on the lugs. Hopefully they get the hub bores right and everything works this time. Fingers crossed...
