Black Pearl Worklog
Old Apr 20, 2012 | 12:03 PM
  #46
Kuro's Avatar
Kuro
I like your work man can't wait to see them on your G
What are the offset?
Old Apr 21, 2012 | 02:04 AM
  #47
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
Thank you. The wheels are 20X9 +38 all around with a deeper lip on the rear. They'll fit a BBK as well, that's coming soon too!
It's a little conservative for the eibach drop, but I may go to coilovers soon. If not, I'll just put a small spacer on the rear.
Old Apr 21, 2012 | 02:24 AM
  #48
LegitMW's Avatar
LegitMW
I think you'll need spacers all around. That seems like it will be really tucked in.
Old Apr 21, 2012 | 02:30 AM
  #49
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
I'm running 20mm front spacers and 25mm rear's right now with the stocks. I checked the specs on an offset calc to confirm and checked with Ravspec and Work. This should be a pretty good fit. Fingers crossed.
Old Apr 21, 2012 | 02:58 AM
  #50
LegitMW's Avatar
LegitMW
Idk if it differs for 20's but for example...
stock sport 19's fronts are 19x8.5 +43.
your aftermarkets 20x9 +38
Your aftermarket is basically 11mm bigger than stock sport wheels. And to be flush in the front with eibach drop, a 20-25mm spacer is needed with stock.
I used this as a wheel calculator. Wheels and Tires Forum Sponsored by The Tire Rack - E90Post - BMW 3-Series (E90 E92) Forum
Old Apr 21, 2012 | 03:20 AM
  #51
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
"6mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 20mm" That's what I got with the calc. Also I had Mark from Ravspec confirm it would be a good fit. A 10mm spacer is still better than the 20,25's I was running.
Old Apr 21, 2012 | 03:33 AM
  #52
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
I'm nervous now...
Old Apr 21, 2012 | 03:34 AM
  #53
LegitMW's Avatar
LegitMW
I see. Well hope everything turns out well ! Can't wait to see the pics
Old Apr 21, 2012 | 03:37 AM
  #54
LegitMW's Avatar
LegitMW
Haha sorry I didn't mean to scare you. It's just I have custom offsets Forgestars and I'm also on eibach drop. And they're pretty flush. I'm sure I could add a 5mm spacer to the back and front but I'm fine with it and don't want to deal with the hassle
I have 19x9 +27 Fronts
19x10 +33 Rears
Plus yours are 20X9 +38 all around. So the rear will be more tucked in...I don't think the deeper lip will affect how much more the entire wheel will stick out.
Idk how you got 20mm extra on the calc if you put in.
8.5 width +43
9 width +38
Old Apr 21, 2012 | 03:42 AM
  #55
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
It's cool, I just don't want to be super disappointed. Here's hoping for the best! Legit, are you an X coupe?
Old Apr 21, 2012 | 03:46 AM
  #56
LegitMW's Avatar
LegitMW
Nope, but I'm assuming what sits flush on a regular non X coupe would be the same on a X coupe (putting awd etc aside). Same car afterall.
Old Apr 21, 2012 | 04:18 AM
  #57
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
It's close, but the Eibach spring rate's are different (X/S/Reg) and I think that the stock offset is a little different as well (+43/+45). Let's hope this makes the difference, I really don't want to be running giant spacers.
Old Apr 23, 2012 | 02:01 AM
  #58
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
OnEighty Custom heads and tails
Old Apr 23, 2012 | 02:02 AM
  #59
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
Thanks 180! Great work!
Old Apr 23, 2012 | 09:03 AM
  #60
Gville37's Avatar
Gville37
dude...great looking headlights. what modifications you get done to them?
