Special Motive Power Bleeder from Jeb Performance
i can attest that this is a great product! bought one many years back to use with my honda.
i now have an infiniti and require the adapter, do you sell seperately?
if so what is cost and also shipping to canada?
thanks!
thanks!
Braking system when fluids exceed boiling point will produce bubble inside your calipers. Reducing braking power, fading may occur, and reduce longevity of your brake system.
Bleeding you brake can be little tricky. Primitive way of bleeding would be one person pumping the brakes while another person would open and close the bleeder nipples. Primitive but effective. But takes two person.
I have used in the past many bleeding system. Most common you will see on the market are vacuum system attached to nipples while you open and close the valve. This way of bleeding is tedious and ineffective.
Motive a racing products manufacturer have come up with brilliant idea. Apply pressure to your master cylinder. Using their kit is most convenient, effective, and yes takes only one person. Done in no time.
Jeb Performance recommend your brake system to be bled at least once every time you change your brake pads or rotors.
Retail Price on Motive Power Bleeder Kit 0107 is $64.95 plus shipping. You will not find elsewhere. Kit comes with following parts. Bleeder, Adapter which fits Infiniti/Nissan, Subaru, and Dodge. So there is nothing else to buy. Also we provide adapters only, for your application on any vehicle please refer to Motive Adapter and Bleeder Application GUIDE.
Instructions on how to use, and to see how easy they are. Please watch instructional video provided by Motive Products. The video is not narrated so there is nothing wrong with your sound system.
Order your Motive Power Bleeder @ POWER BLEEDER - JEB Performance, Inc. - Thousands of after market tuning parts for less
<iframe title="YouTube video player" src="http://www.youtube.com/embed/d0h5bMoW-aw?rel=0" allowfullscreen="" frameborder="0" height="510" width="853"></iframe>
i can attest that this is a great product! bought one many years back to use with my Honda.
i now have an Infiniti and require the adapter, do you sell separately?
thanks!
