Special Motive Power Bleeder from Jeb Performance
Old Aug 24, 2011 | 07:08 PM
  #46
JEBperformance's Avatar
JEBperformance
nice price! GLWS
Old Aug 25, 2011 | 02:59 PM
  #47
JEBperformance
Braking system when fluids exceed boiling point will produce bubble inside your calipers. Reducing braking power, fading may occur, and reduce longevity of your brake system.
Bleeding you brake can be little tricky. Primitive way of bleeding would be one person pumping the brakes while another person would open and close the bleeder nipples. Primitive but effective. But takes two person.
I have used in the past many bleeding system. Most common you will see on the market are vacuum system attached to nipples while you open and close the valve. This way of bleeding is tedious and ineffective.
Motive a racing products manufacturer have come up with brilliant idea. Apply pressure to your master cylinder. Using their kit is most convenient, effective, and yes takes only one person. Done in no time.
Jeb Performance recommend your brake system to be bled at least once every time you change your brake pads or rotors.
Retail Price on Motive Power Bleeder Kit 0107 is $64.95 plus shipping. You will not find elsewhere. Kit comes with following parts. Bleeder, Adapter which fits Infiniti/Nissan, Subaru, and Dodge. So there is nothing else to buy. Also we provide adapters only, for your application on any vehicle please refer to Motive Adapter and Bleeder Application GUIDE.
Instructions on how to use, and to see how easy they are. Please watch instructional video provided by Motive Products. The video is not narrated so there is nothing wrong with your sound system.
Order your Motive Power Bleeder @ POWER BLEEDER - JEB Performance, Inc. - Thousands of after market tuning parts for less
<iframe title="YouTube video player" src="http://www.youtube.com/embed/d0h5bMoW-aw?rel=0" allowfullscreen="" frameborder="0" height="510" width="853"></iframe>
Old Aug 26, 2011 | 07:33 PM
  #48
JEBperformance
Have a nice weekend
Old Aug 31, 2011 | 09:02 PM
  #49
JEBperformance
FREE bleeding from JEB Performance
Old Sep 2, 2011 | 02:50 PM
  #50
JEBperformance
Getting ready for the weekend. We will reply to your PM promptly after the long weekend. Thank you for all your inquiries and have a great weekend.
Old Sep 16, 2011 | 05:23 PM
  #51
JEBperformance
Finally Friday, wish me luck tomorrow at racing track. I am going to test some new parts. Thank you.
Old Sep 27, 2011 | 04:50 PM
  #52
JEBperformance
Just to bleed brake lines shops will charge $70? will DIY and you will save $$$$$$$. With this one man bleeding system.
Old Sep 30, 2011 | 06:14 PM
  #53
JEBperformance
I get orders from Auto Shops for Motive Bleeders.
Old Oct 6, 2011 | 05:22 PM
  #54
JEBperformance
ALL PM replied thank you for the opportunity
Old Oct 18, 2011 | 04:02 PM
  #55
JEBperformance
Spectacular price PM US
Old Oct 21, 2011 | 01:43 PM
  #56
JEBperformance
PM us for best price. We will reply with all your questions. And above all greater price for this weekend only.
Old Nov 3, 2011 | 04:26 PM
  #57
JEBperformance
We refuse to keep our tools stock
I have many instances when our customer especially from Performance Shops who purchased MOTIVE Power Bleeder from us. Yes the cap can be replaced to fit almost all the vehicle out there. However while replacing, brass couplers tend to get stripped. Nonetheless is an hassle to replace adapters when moving from one vehicle to another.
So here is simple yet powerful solution Under $10. By fitting Quick Release Couplers on all your hoses. Which enables moving from one car to another a breeze.
Lets go over couple of things you will need for this JOB.
  • 1x 1/4" Male Brass Quick release Coupler
  • 1/4" Female Brass Plug Depending on how may cars you own, or how many Master Cylinder Caps (Adapters) you have.
  • Teflon Thread Seal Tape
  • Flare Nut Wrench So you don't strip brass bolts.
  • When you have all the above you are good to go.
  • Roll 3-4 ply of teflon tape around each brass couplers.
  • Like so ..............
  • Bolt the 1/4" Female Brass Plugs hose ending in Master Cylinder CAP.
  • Make sure to tighten well.
  • This phase is when later leaks can occur.
  • Careful not to strip the nuts.
  • Now lets do the hose from the MOTIVE POWER BLEEDER.
  • Use 1/4" MALE Quick Release Coupler for the JOB
  • Make sure to use Teflon Tape on this job as well.
  • Once bolted in you are almost finished.
  • Changing cap now is easy as snap in and out.
  • SNAP IN
  • SNAP OUT
  • Final step is to fill the bleeder with water.
  • Presuarize to 25psi and check for any leaks.
NOW YOU ARE GOOD TO GO..................
For shops or DIY guys out there. Who Purchases multiple Adapters from US. We will fit the quick release couplers free of CHARGE. So PM us or call us for more details.
Old Nov 3, 2011 | 07:14 PM
  #58
JEBperformance
Spectacular November SALE ONGOING PM US any part you want.
DO not forget to let us know your year and model of your G37.
Old Nov 3, 2011 | 07:49 PM
  #59
buckets's Avatar
buckets
This is a great tool to have, be sure to use teflon tape on fittings to avoid leaks.
Old Nov 4, 2011 | 03:39 PM
  #60
JEBperformance
A Proper torque alone is good enough for air tight seal. Teflon tape is just to make sure.
