Special StopTech rotors
Old Aug 22, 2011 | 07:17 PM
  #91
JEBperformance's Avatar
JEBperformance
STOPTECH most dependent brake parts
Old Aug 23, 2011 | 11:57 PM
  #92
JEBperformance
pm us for rotors and pads combo deal
Old Aug 24, 2011 | 06:52 PM
  #93
JEBperformance
Which rotor is right one for me?
To put in simple terms, it all depends on your local weather. Extremely hot geographic area with little rain use drilled rotors. Extremely cold and wet to snow geographic areas recommended use of slotted rotors. Not so cold and have little bit of both from hot and wet use drilled and slotted rotors are recommended.
Drilled rotors if run on extremely cold weather like north pole after 20'000 miles of use may see cracks on the edges of the drilled holes.All drilled rotors from Stoptech are diamond cut. After the rotors wear out may cause cracking.
Slotted rotors helps wipe water away from the rotor, however does little for dissipating heat.
Slotted or Drilled Rotors will cost less than your OEM brake rotors at the Dealer. Less vibration under braking. Very quiet and smooth braking.
Easier than you thought Right? So PM us for your brake rotors NOW!!!!!!!
C-TEK Standard Rotors
C-Tek brake rotors offer an alternative replacement rotor and are available in a wide variety of applications both import and domestic. All C-Tek rotors feature an double-disk ground finish.Double Disc Ground
Centric premium rotors feature a double disc ground, taper free finish. Double disc grinding ensures parallelism, eliminates run out and provides near perfect disc thickness variation (DTV). Double disc grinding leaves a non-directional finish on the friction surface area for more effective pad-rotor break in. This special finish also provides quieter and smoother stops.
C-TEK Standard Rotors for G37 Base brake system - front MSRP $98.75
C-TEK Standard Rotors for G37 Base brake system - rear MSRP $84.95
C-TEK Standard Rotors for G37 Sport brake system - front MSRP $95.65
Power Slot Slotted Rotors
Power Slot is Centric’s performance division focusing on entry level brake upgrade solutions. Power Slot pioneered direct fit performance rotors for trucks, SUVs and severe duty vehicles, delivering superior and reliable braking even under hard driving conditions. Excessive heat can cause resins in your brake pad to vaporize or “outgas.” As the brake pad wears, the used friction material turns into a fine dust. This boundary layer of heat, gas and dust builds up between the pad and rotor surfaces and inhibits performance.
Power slot Slotted Rotors for G37 base brake system - front right MSRP $189.71
Power Slot Slotted Rotors for G37 base brake system - front left MSRP $189.71
Power Slot Cryo Treated Slotted Rotors for G37 base brake system - front right MSRP $219.71
Slotted Rotors for G37 base brake system - front leftMSRP $219.71
Power Slot Slotted Rotors for G37 Sport brake system - front right position
MSRP $218.00
Power Slot Slotted Rotors for G37 Sport brake system - front left position
MSRP $218.00
Power Slot Slotted Rotors for G37 Sport brake system - rear right position MSRP $169.29
Power Slot Slotted Rotors for G37 Sport brake system - rear left position
MSRP $169.29
Premium Cryo Treated Rotors
Centric Premium black rotors feature Original Equipment specifications and production processes. These Centric rotors are manufactured to meet QS and ISO Quality System Standards.
Centric premium rotors utilize an Electrocoating finish that provides long lasting corrosion protection. E-coating is a superior electro-statically applied finish designed to withstand 400 hours of salt water exposure without rusting. Phosphate finishes utilized by other manufacturers provide only minimal protection from the elements; these finishes are generally only effective for the shipping and storage portion of a rotor’s life. The addition of heat and moisture eliminates the effectiveness of phosphate finishes resulting in immediate corrosion once installed in the vehicle.
Premium Cryo Treated Rotors G37 Base brake system - front MSRP 164.56
Premium Cryo Treated Rotors G37 Base brake system - rear
MSRP 121.00
Premium Cryo Treated Rotors G37 Sport brake system - front MSRP 233.20
Premium Cryo Treated Rotors G37 Sport brake system - rear MSRP 165.00
SportStop Drilled and or Slottled Rotors
Cross drilled or drilled and slotted brake rotors prevent glazing of the pads, add bite and improve wet and dry braking performance. The addition of high performance street pads provide you with higher resistance to fade, higher maximum operating temperature, and better initial bite to allow consistent deep braking into corners. Motul RBF600 brake fluid increases both wet and dry boiling points and prevents boiling even under the most severe operating conditions. Good for street and autocross. Not for extended track sessions.
Most SportStop performance rotors feature our special Power Alloy metallic compound.
ONLY AVAILABLE FOR G37 WITH SPORT BRAKE SYSTEM
SLOTTED
Front right MSRP $190
Front left MSRP $190
Rear right MSRP $180
Rear left MSRP $180
SLOTTED & DRILLED
Front right MSRP $205.71
Front left MSRP $205.71
Rear right MSRP $178.57
Rear left MSRP $178.57
Only offered from JEB Performance when you buy any StopTech Brake Rotors from us. We will inlcude 14.oz bottle of brake cleaner absolutely free. So you can always run your rotors with out gunk, dust, and rust. A $10 value absolutely FREE. Limit one per pair, a courtesy from Centric Parts.
14 Oz. Ultra-Low VOC Brake Cleaner
Degreases & Derust quickly and can be used without disassembling the brake unit.
Price based on US Domestic shipping only
Old Aug 25, 2011 | 03:22 PM
  #94
JEBperformance
Stoptech rotors = Day.
OEM rotors = Night
Brighten your braking without vibrations, performance, and above all lower price. With StopTech Performance Rotors.
Old Aug 26, 2011 | 07:28 PM
  #95
JEBperformance
Have a nice weekend
Old Aug 27, 2011 | 04:26 AM
  #96
G35_FTMFW's Avatar
G35_FTMFW
Front drilled and slotted for sport brakes to 33615. cyro treated price as well
Old Aug 30, 2011 | 05:27 PM
  #97
JEBperformance
PM sent, thank you
Old Aug 31, 2011 | 08:05 PM
  #98
JEBperformance
Best reliable STOPTECH Rotors
Old Sep 2, 2011 | 02:53 PM
  #99
JEBperformance
Getting ready for the weekend. We will reply to your PM promptly after the long weekend. Thank you for all your inquiries and have a great weekend.
Old Sep 16, 2011 | 05:20 PM
  #100
JEBperformance
Finally Friday, wish me luck tomorrow at racing track. I am going to test some new parts. Thank you.
Old Sep 27, 2011 | 04:59 PM
  #101
JEBperformance
STOPTECH BEST LOOKS and performance
Old Sep 30, 2011 | 06:09 PM
  #102
JEBperformance
We also carry blank rotors from StopTech. Hundreds less than OEM Cost.
Old Oct 1, 2011 | 01:30 AM
  #103
G-Lover's Avatar
G-Lover
Please PM me a price for front and rear drilled StopTech rotors with pads shipped to 91105. Thanks!
Old Oct 1, 2011 | 03:20 AM
  #104
jamesshifflett's Avatar
jamesshifflett
Please PM prices for Drilled shipped to 91001. Sport brake setup
Old Oct 1, 2011 | 05:35 PM
  #105
kaoticdemize's Avatar
kaoticdemize
pm price for stop tech rotors front and rear 2010 sedan (non sport) looking for best for track use. Shipped 95122
