Special CKS SUSPENSION NOW AVAILABLE exclusive from AMPLIFIED MOTORSPORT
Old Dec 21, 2010 | 08:00 PM
Lou@Amplified's Avatar
Lou@Amplified
CKS SUSPENSION
model : C1
New alluminum and black colors
laser etched ***** for adjustment
- All uppermounts, spring perch and lower mounts are made of forged aluminum (7075 grade), then each piece is hard anodized for better wear and corrosion resistance
- Bump stop and dust boot are intergrated together into one piece to prevent the dust boot from curling up like the traditional dust boot, and also to minimize contamination and protects shaft and seal
- 24 levels of dampening adjustability can be set to any preference
- SCM440 hardened piston rod
- 44mm linear characteristic internal piston
- Mono-tube design ( inner polished seamless 55mm tube)
- Italian IP F.A 5W made very high viscosity index, guarantees efficient shock absorbing action at any ambient temperature
- Lower bracket height adjustability prevents the needs to adjust the spring perch, offering the max shock travel
- SAE9254 cold bent spring is designed to optimize the balance between performance and comfort
- We repeatedly do street and track tests to ensure our products are suitable for customer in any different condition
- Each suspension is individually wrapped in bubble wraps to protect it from any possibilitiy of getting damaged.
- Struts can be repaired/ rebuilt here in the USA (A BIG PLUS)
- 2 YEAR MFG WARRANTY unlike most coilovers that gives 1 year
MSRP $ 1899
INTRODUCTORY PRICE IS $1400 SHIPPED with in the 48 states.
Anything outside of that is extra
This coilover system is only available through AMPLIFIED MOTORSPORT
AWD system will be available soon.
Once order is placed, turn around is a week plus shipping
Please call or PM me for any questions.
thank you
Lou
323 8810882
Old Dec 21, 2010 | 10:09 PM
4drScreamer's Avatar
4drScreamer
Great another option. Lou, has anyone tested these out for ride quality yet?
Old Dec 21, 2010 | 10:28 PM
Lou@Amplified
I actually had the prototype on my car. Once set at medium dampening. It was pretty good already. I'm sure you can set this even softer than stock. That's the good part on having the adjustable dampening.
Old Dec 22, 2010 | 03:43 AM
Q8y_drifter's Avatar
Q8y_drifter
The sedan guys will love the AWD option! Make sure you post it on G35driver
TheLocNar
Dec 22, 2015 07:52 PM
Soccer4555
Sep 30, 2015 05:31 PM
