Special K-Sport Kontrol Pro Damper Coilovers
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of damping adjustment allow you to fine tune the ride to your handling and comfort needs. The damping adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Where available, camber canbe adjusted via the Pillow-ball Top Mounts, which means no additional "Camber Kits" are needed.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer damping adjustments, and requires more expensive design process. Aeration and cavitation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features:
- 36 levels of adjustable damping
- Made from high quality 6061 aluminum with T6 for increased hardness
- Compression/Rebound adjustable
- Adjustable spring perch for height adjustment
- Adjustable body allowing maximum suspension travel
- Pillowball top mount with adjustable camber (not available for some models)
- Monotube high pressure design reduces oil leakage
- Electroplated body for protection from corrosion and rust
- One year limited warranty
MSRP: 1400
PM for Pricing
Thank You
Key Features:
MSRP: 1400
PM for Pricing
Thank You
I hit the track with these installed a few weeks ago and I can honestly say I was IMPRESSED. Had the fronts set at 22 and the rears at 18 and handling was awesome. Hardly any body roll (on stock sways) and had no issues. Best bang for the buck coilovers on the market imo
timc00k
Feb 15, 2017 09:15 AM
optikol
Jan 28, 2016 07:31 PM
