Special Megan Racing Street Coilover Kits - In Stock - $900 Shipped @ Import DPS!!
*** Megan Racing Street Coilover Systems - Part #MR-CDK-IG082D - $900 Shipped ***
Click Here to See More Pictures with Install Shots - Megan Racing
MFG Info - Infiniti G37 Coupe 08+
Model Number : MR-CDK-IG082D Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in **** at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: 12kg Front and 10kg Rear
- Front and Rear Pillow Ball
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
- All coil over damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
We accept Visa, Mastercard, American Express and Discover Cards. Cash Local Pickups are also welcome on this. Call us at 215-227-6000 to order. PM us if you have any questions.
Time and time again we get people that ask if we are just a internet store or actual shop. Nyce1's.COM is one of the featured online resources for Racing Videos and up close videos of all the top shops out here in the North East. They recently came down and recorded us on a Saturday and posted the video up. As you get a chance, take 5 minutes out your day to check out what Import DPS Speed Shop is all about.
Click Here -> YouTube - Nyce1s.com - Import DPS Up Close June 2010!!
Thanks in Advance.
Rick
Import DPS
