Help Need help choosing wheels for winter setup
I will be buying dedicated winter tires/wheels. Are there any 17s that fit over the sport brakes? I plan on getting sport brakes further down the line.
I suggest buying a set of the OEM 17 X 8.0" alloy wheels. They fit over the Akebono front monoblock calipers, but other "sport" brakes may not.
Also, the Akebono calipers aren't monoblock, they're 2-piece.
For winter I use 18 x 8, with a 225-50-18 X-ice... works fantastic!
Duckfeet are the path most take for winter wheels if they are running the Akebono sport brakes.
And I stand corrected as well: I meant to refer to the 18" OEM alloys as well. The duckfeet rims fit just fine over the Akebono monoblock calipers. BTW- monoblock calipers are a racing innovation that allows brake pads to be replaced from the top during a pit stop, In production trim, a monoblock caliper is built from two sections bolted together and has a much higher heat sink capacity than a sliding caliper.
A two-piece caliper is not a monoblock.
Also, your measurements on the Sport Sedan wheels are off. They were 18x7.5, except for the staggered rears on the RWD Sport package, which were 18x8.5.
classy37
Oct 31, 2011 02:51 PM
