Help Is it possible to create mounts for a 3-point front strut tower bar in a g37
Old Dec 19, 2023 | 11:10 PM
Bradze's Avatar
Bradze
This was an impulse buy. Figured it’d fit but not quite.
Old Dec 20, 2023 | 08:00 AM
BULL's Avatar
BULL
Moderador
So I've noticed the middle area on the Z and so far I'm not convinced that the middle aspect of the brace is actually doing much for the car.
It uses a very thin 90 deg bracket that bolts to the bar and it's spot welded onto the firewall.
This would force you to make sure the third mounting spot needs to be as solid as possible however either OEM Z could benefit from reinforcement or that since the main bar is so wide there very little gain from the rear bars which is why the mounting surface was weak.
Either way it will require some decent modification and possibly cutting into the firewall side to get it to go in. If this is too much and you dont plan on selling you could always cut them off and keep the main bar. Doubt there will be much difference in the feel by not installing.
Old Dec 20, 2023 | 12:24 PM
Bradze's Avatar
Bradze
Thanks for detailed response. As usual I bit off more than I could chew. I’m planning on keeping car long long time. It doesn’t really have any value. I may need to track down a wrecked 370Z
13_G37x
Oct 24, 2018 08:42 PM
vquezada24
Jun 13, 2015 11:16 PM
dainjarouz
MODDING 411
May 1, 2010 08:26 PM
dranom
Brakes
17
May 5, 2009 02:22 PM
