Sport suspension
Old May 12, 2020 | 12:54 PM
G37sPhoton's Avatar
G37sPhoton
Sport suspension
My 2011 w/sport suspension is right at 122k miles and as i plan on keeping it a while longer, im looking at changing out suspension now and enjoy it rather than when needed....car is not bad/floaty etc or anything like that, but definitely not like when new, so looking at opinions/options on what to get to keep near stock sport set up- I had considered a mild drop with the tanabes nf210 and thought maybe just replace the springs with tanabes but what shocks work best for OEM or even better ride set up etc...the drop is not a must as i have lived with it this long, so not a major issue, but open to it if i can make it work...
Old May 12, 2020 | 10:38 PM
Dentt42's Avatar
Dentt42
For about two months I’ve been running a set of Swift springs and low mileage 370Z sport struts, and it’s been a huge improvement. Since you’re now used to the soft springs and worn out struts, the steering will feel amazing after upgrading. My long term plan is to upgrade the struts to Konis, but the used Z struts with 25K miles were about $140 shipped and well worth the money and a Saturday afternoon.
Swift seems to be the most popular with G37’s from what I’ve seen, but I think that was also because they work with stock struts. I personally picked them because they put the ride height exactly where I wanted without having to be adjustable. Whatever you pick, it’ll be worlds better than what you’re accustomed to.
Old May 13, 2020 | 08:21 AM
G37sPhoton's Avatar
G37sPhoton
Thanks and Yes , I read a lot of posts for swift but was concerned on the drop being over 1inch and then camber kits needed etc...how's your ride height and any adjustments ? So yeah, hope for a new feel type as the car now has aged, but yes your approach sounds good, so will look for some z part outs etc as that price is nice for my susp budget lol..
Old May 13, 2020 | 09:33 AM
Dentt42's Avatar
Dentt42
The drop listed at about an inch and a half only seems like a lot because the front fender gap is so huge on these cars from the factory. I haven't had any problems with scraping, and it's not nearly enough to require anything expensive for alignment. My Z1 rear lower camber arms are probably overkill, and I mostly got them to eliminate the factory eccentric for better strength. Looks wise, I'm in love with the way the car sits, and it's not slammed at all.
Old May 13, 2020 | 10:21 AM
Lego_Maniac's Avatar
Lego_Maniac
Koni Yellows on full soft are on par with the OEM sport shocks.
Old May 14, 2020 | 08:38 AM
G37sPhoton's Avatar
G37sPhoton
Thanks and yes, funny how the gap doesn't bother me until I start to really look at the car ....then yeah...so swift and Konis may be a good setup...still leaning on tanabes just for price and drop being minimal, at least based on some older posts , so wondering how they would work with 370sport struts....I'm not driving the car much , only weekends so trying to minimize how much i put into it at this point , and as Dentt42 mentioned , at these miles on oem susp, most anything will feel better ....thanks
Old May 14, 2020 | 02:01 PM
Surfnazi's Avatar
Surfnazi
you could put on a set of shocks and springs off a 370z nismo and get .5 inch drop and will still align to factory specs
Old May 15, 2020 | 02:11 PM
G37sPhoton's Avatar
G37sPhoton
..... that sounds ideal actually, thanks man!
Old May 19, 2020 | 07:23 AM
Surfnazi's Avatar
Surfnazi
check z forum they are always selling. Do buy new springs pads and strut mounts
Hollywood619
Sep 13, 2014 11:52 AM
davewittes
Jun 20, 2013 01:31 AM
350zrb
May 5, 2010 07:09 PM
ajumlvr
Nov 7, 2007 03:54 AM
