Banjo Fitting Brake Lines on Akebono Calipers
Old Oct 14, 2019 | 02:13 PM
camb003's Avatar
camb003
Recently installed this Brake Upgrade Package on 2010 G37S. https://www.z1motorsports.com/z1-pro...ge-p-4490.html.
Held back on installing brake lines since I am looking to also paint calipers in the near future but also because I noticed a different brake lines configuration than original.
OEM brake line fittings for Akebono calipers are straight at the end. The lines that came with the Brake Upgrade Package kit have banjo fittings at the end. Z1 also sells brake lines with straight fittings just like the ones installed but recommend to use the banjo fittings to avoid "more points of failure". I looked this up and it seems the banjo fitting lines are longer and so they will work.
Attached are 2 pictures. One is the banjo fitting installed on a rear brake caliper/line (can't tell if it's Akebono) and the other one shows where the 2 brackets that come with the front brake line with banjo fitting would need to be installed for it to work.
Has anyone installed this banjo fitting lines on Akebono Brake Calipers?
Rear Brake Line with Banjo Fitting installed
Front Brake Line Braket Locations
Old Oct 14, 2019 | 02:18 PM
camb003's Avatar
camb003
Brake Lines Banjo and Straight
Attached are the lines sent with the kit as well as the original brake lines with straight fittings.
Straight end fitting brake lines
Banjo end fitting brake lines
rohtx713
May 31, 2015 07:18 PM
daonlyillwiz
Mar 27, 2014 05:06 PM
SPN27RU
Sep 16, 2013 08:57 AM
MikeKiloDelta
Jun 20, 2013 11:40 AM
Shurik355
Jun 29, 2012 05:57 PM
