New OEM Rims for '13 G37X
Old Apr 24, 2019 | 12:06 AM
sp3379's Avatar
sp3379
Hey everyone,..
I am thinking of getting new 19 inch rims for my 2013 G37X but unsure where to start, I really fell in love with the OEM 10-spoke ones (Pic attached). Does anyone know where to find these brand new and cheap with good tires? What size should I get if I want to go a little wider?
Also, anyone have any good tips on where to buy some nice red brake calipers for front and cross-drilled slotted brakes for all around?
Old Apr 24, 2019 | 09:31 PM
Hi,
Those are pre-2013 coupe wheels so finding brand new ones will cost quite a bit since they're probably only available from the dealer. Should be able to find used ones in good condition in the $600 range. They come staggered w/ 19x8.5 front running 225/45/19 tires and 19x9 back w/ 245/40/19 tires. For a wider set on AWD coupe I'd look for 19x9.5 +35 offset and you can run 255/40/19s all around.
As far as red calipers, check this thread
https://www.myg37.com/forums/brakes-...-calipers.html
Old Apr 25, 2019 | 01:34 AM
sp3379's Avatar
sp3379
Hi thanks so much for that info! Question, so my G37x is a 2013 Sedan, would I still be able to run 19x9.5 all around? Or do they still have to be 19x8.5 in front and 19x9 in back?
Old Apr 25, 2019 | 08:24 AM
19x9.5 would have to be an aftermarket wheel, if you want the wheels you posted they only come in that 8.5/9" set, you can run the staggered wheels but be sure to run 245/40/19 tires all around for your AWD and keep the wider wheels in back.
NaumanXenon
Mar 1, 2012 12:49 PM
Steveo47
Feb 20, 2010 01:16 AM
