Spring rating for sedan g37x
Old Apr 9, 2019 | 12:13 PM
Stachuu's Avatar
Stachuu
Question.
Besides spring rating, is there any other difference between sedan RWD and sedan AWD struts or coilover kits?
I found coilovers with following rating that I think would work well on my 37x sedan, I currently have swift springs on my car that I have had for 30k miles, and my front struts are in bad shape now.
I was going to go with Monroe struts and other components that dont come with the strut but, doing just the front is close to ~370 bucks. I could get the whole kit that covers front and back for little more.
Any thoughts?
Spring Rate(Front)14 kg/mm (784 lbs/inch)
Spring Rate(Rear)12 kg/mm (672 lbs/inch)
Old Apr 9, 2019 | 12:44 PM
Baadnewsburr's Avatar
Baadnewsburr
The rears are the same for AWD and RWD models but the fronts are physically different in shape and structure.
The fronts cannot be be interchaged. THE AWD struts mount on a fork that the front axles go between and are much shorter, the RWD front struts mount directly to the LCA...
See the sticky in the suspension section of the forum on coilovers made for AWD cars
Old Apr 9, 2019 | 12:59 PM
Stachuu's Avatar
Stachuu
Thanks man!
I had feeling something was off, I read sticky some time while ago and couldnt recall.
Old Apr 10, 2019 | 10:18 AM
It's crazy that there really aren't any aftermarket alternatives for shocks for the AWD platform. Even finding ANY replacements can be a chore, looks like this is a decent deal & you'd just have to swap springs & lower fork mounts. Comes with the top mounts and those can be expensive to replace from the factory.
https://www.1aauto.com/infiniti-stru...BoCmlgQAvD_BwE
Old Apr 10, 2019 | 02:32 PM
Stachuu's Avatar
Stachuu
Thats a pretty good deal, I just pick up spring compressor from harbor freight for 30 bucks and should be golden.
Thanks!
Old Apr 10, 2019 | 04:31 PM
Thanks!
Be careful w/ those, I'd rent from AutoZone or O'Reillys they're much stronger & safer.
Old Apr 10, 2019 | 05:53 PM
Stachuu's Avatar
Stachuu
Yeah, I will look around before new struts arrive, Id rater have my own set than keep renting.
By the way the website has some really good deals, I hope the quality is just as good.
radguy88
Intake and Exhaust
Sep 25, 2014 07:22 AM
Kidcane
Site Feedback & Suggestions
27
Jan 9, 2010 02:17 PM
myk1013
Mar 21, 2008 01:41 AM
phenom1011
Future Models
Nov 2, 2006 06:19 PM
