How much of Energy Suspension bushing set for 350 = G37x?
Old Jan 3, 2019 | 10:22 AM
m3clubracer's Avatar
m3clubracer
Big general question here. Does any one know how much of a bushing set from energy suspension for a 350Z would be the same for a G37x? I know the main rear lower bushings are the same!
Old Jan 3, 2019 | 10:35 AM
Baadnewsburr's Avatar
Baadnewsburr
are you talking about the master bushing set (i.e. poly bushing set for everything?) its not likely to be interchangeable for suspension parts at the front for the G37 as the entire LCA setup is different and probably doent even have the same number of bushings ... for the x model even more so as the entire front subframe is different as are the LCAs...FUCAs and the rear suspension bushings might fit though except the rear subrame bushings..the rear bushing piece worked because the 350/g35/g37 all use the same R200 differential and they use nearly the same size mounting hole
Old Jan 3, 2019 | 02:27 PM
m3clubracer
I needed the rear bushings and this was my only option and was looking to sell or keep the rest. Thanks!
oro
Mar 31, 2013 04:55 PM
TJHG37S
Jun 19, 2012 01:42 AM
GollyGee
Jan 22, 2012 11:54 PM
