Drilled slotted rotor noise pressing brake pedal?
Old Dec 26, 2018 | 03:43 PM
jaydee23's Avatar
jaydee23
I installed new wheels tires springs rotors calipers and pads
so..a lot of new stuff
The rotors are drilled and slotted bbk akebono size
Everything is beautiful.. Quiet.. Aligned and in perfect working order.
However
I get this unusual sort of noise vibration when braking. It happens from about 40 to 35 mph..
The frequency is like driving over a median strip design to make noise and alert you your out of your Lane.
But it's light and not bad at all. I'm ocd and I can live with it. Just curious what it might be.
It's got to be either the rotors or the tires. I doubt it's the tires.
I've never had drilled and slotted rotors before.
Anyone experience this with these type rotors?
Old Dec 26, 2018 | 05:57 PM
Gio37's Avatar
Gio37
with new rotors & pads did you do bed-in process ?
Old Dec 26, 2018 | 06:49 PM
jaydee23's Avatar
jaydee23
I did
followed the power stop procedure which is basically 5 moderate stops and 5 aggressive stops.
Old Dec 26, 2018 | 09:13 PM
takemorepills's Avatar
takemorepills
In my experience, drilled/slotted rotors make noise. It's not usually too bad, just how the holes and slots create some noise as they pass by the brake pads. It can even happen when not using the brakes.
shawnberry45
16
Oct 2, 2020 05:43 PM
warped ideas
Jan 26, 2016 07:05 PM
avatar77
Sep 22, 2014 12:23 AM
nestle_!9
Jul 1, 2008 10:57 PM
