Help Work vsxx will they fit?
Old Dec 16, 2018 | 09:33 AM
1ndian's Avatar
1ndian
So I’m interested in purchasing some work vsxx and I found a used set, but here’s the problem it’s a 20x10 and 20x11 +25 on both. I’m wondering if they’ll fit my g37 coupe. And if they do fit what tire size should I run, I would like to stay away from stretched tires but I think I have no choice with this size and offset. Also my Infiniti has tein coil-overs and spc camber arms. Any insight will be helpful.
Thanks
Old Dec 16, 2018 | 12:13 PM
Thanks
Since you have the SPC kit you can add camber as needed, but yeah stretch tires are probably going to be needed, at least in back, probably run 275s all around, which isn't a stretch in front but is on an 11. Also you'll need to confirm brake clearance if you have an S coupe.
Old Dec 16, 2018 | 03:22 PM
1ndian's Avatar
1ndian
Yeah I messaged the guy and he said I’ll need a spacer to clear the bbk. Okay how much camber would I need to run to get them to fit.
Old Dec 16, 2018 | 04:49 PM
PNW_IPL's Avatar
PNW_IPL
probably -2 to -2.5 rear. Front shouldnt need much at all.
Old Dec 16, 2018 | 06:01 PM
Depends how much spacing is req'd to clear the brakes, so that one is a bit of a mystery.
Old Dec 16, 2018 | 07:39 PM
1ndian's Avatar
1ndian
Wow Thanks for help. He said he would get 10 mm to clear the bbk, but who knows. Hopefully all goes well and I’ll be able get to them. Thanks once again
Old Dec 16, 2018 | 10:59 PM
10mm is quite a bit as far as making adjustments to camber or stretch, may have to go w/ a stretch 255 in front and that 275 in back.
Old Dec 16, 2018 | 11:34 PM
1ndian's Avatar
1ndian
Okay maybe I could run a smaller spacer, but I don’t know yet. So I’m currently running some avant-garde 20x10 and 20x11 and they have stretched tires a 245 in front and 275 in the rear. And it’s been giving me problem, but it’s mostly in front that’s why I’m trying to stay away from stretched tires.
Old Dec 17, 2018 | 08:28 AM
A 255 on a 10 should be a better setup as long as the tires are good quality.
Old Dec 17, 2018 | 11:40 AM
1ndian's Avatar
1ndian
Okay cool Thanks for help really appreciate it
Matty_baby
Picture Share G Coupe
21
Feb 6, 2019 03:09 AM
ontheloose
Sep 8, 2014 06:22 PM
RAVSPEC
Wheel & Tires
21
Apr 4, 2011 11:57 AM
7o7G37s
Feb 12, 2009 04:51 PM
looksoverpower
Apr 20, 2008 12:38 PM
