View Poll Results: RCF rims on IPL?
RCF rims
66.67%
Stick to IPL rims
33.33%
Voters: 6. You may not vote on this poll
Lexus RCF rims on G37 IPL
Old Nov 10, 2018 | 05:48 PM
PMTW_IPL's Avatar
PMTW_IPL
RCF rims on IPL? Not sure if anyone's thought of this but I'd imagine it'd look good. Will be squared setup on rear wheel specs if it works out. I want to stick with the same IPL wheel design as I can't see any other wheels on my IPL. Any thoughts/opinions?
OEM IPL wheel specs - 7 split spoke design, 19x9, 5 lugs, 4.5 inch bolt pattern
OEM RCF wheel specs - 10 split spoke design, 19x10, 5 lugs, 4.5 inch bolt pattern
Old Nov 10, 2018 | 05:53 PM
PNW_IPL's Avatar
PNW_IPL
10.5? Square? Will fit the rear but front is pushing it depending on offset.
i vote rcf as long as you dont stretch the tires.
edit.
19x10 square +41 will be perfect!!
Old Nov 10, 2018 | 06:04 PM
PMTW_IPL's Avatar
PMTW_IPL
edit.
19x10 should be perfecty fine on all four. I'm running oem with 20mm spacers and it still has some ways to go before being completely flush. And no stretch lol I plan to track but just want to run wider tires. Looking from the back the rear IPL wheels seem a bit too slim.
Old Nov 10, 2018 | 06:05 PM
PNW_IPL's Avatar
PNW_IPL
Yea man. I was running 19x10 +30 19×11 +20 on My IPL. was perfect. *Youll be able to run some big meat on them!
Old Nov 11, 2018 | 01:17 AM
PMTW_IPL's Avatar
PMTW_IPL
Hoping to put some 285's (295 max) on them. Working on a render to see what it'd look like...
Old Nov 11, 2018 | 10:51 AM
Verify the hub bore, I think it's only 60.1mm on the Lex, the G runs 66.1mm. If the bore was larger than the G no problem, but smaller and you'd need to run an adapter if you could even find one that is
Old Nov 11, 2018 | 03:18 PM
PNW_IPL's Avatar
PNW_IPL
****. Good catch. Thats a big deal!
Old Nov 11, 2018 | 03:28 PM
user 3587587's Avatar
user 3587587
you can always get the bore machined out
Old Nov 11, 2018 | 03:30 PM
PNW_IPL's Avatar
PNW_IPL
yea. Probably not cheap and risky. I wouldnt trust just anyone either..
Old Nov 11, 2018 | 04:01 PM
PMTW_IPL's Avatar
PMTW_IPL
Ahhh I didn't even think about that. Thanks brother I'll look into it. Wish I have someone that had an rcf wheel laying around so I can just test fit.
Old Nov 11, 2018 | 04:09 PM
PNW_IPL's Avatar
PNW_IPL
it wont even go on if the bore is smaller. So you wouldnt even get an idea of how itd fit.
Old Nov 12, 2018 | 01:12 PM
bPChaos's Avatar
bPChaos
If it's a 19x10 +41, you can probably get a 10mm spacer made for a smaller hub bore, and still have plenty of room to spare on the wheel/tire. It'd likely be a custom piece as this isn't exactly a common thing that people do.
Old Nov 13, 2018 | 08:55 PM
PMTW_IPL's Avatar
PMTW_IPL
I've been getting that suggestion too. Just a matter of if there's a shop willing to do it.
Old Nov 13, 2018 | 11:16 PM
You can use a normal 10mm spacer, only problem is they won't be hubcentric (unless you can find a shop to do some custom milling) and this would then negate any "deal" you may be getting on the wheel set. If you run a non hubcentric spacer you may get vibration at higher speeds. I think I'd just pass on them unless you already have them on hand.
