Help Tire Size Option (Lexus)
Old Aug 29, 2018 | 08:27 AM
Goonz's Avatar
Goonz
Exclamation Tire Size Option (Lexus)
Guys my dad needs new tires on his 2013 Lexus ES300h - the car comes stock with 215/55/17 - I wanted to get him something a bit wider since the 215's are super narrow, I'm looking at 225/50/17, 235/50/17 and 235/55/17. Which ones would work best? Note his car is FWD.
Old Aug 29, 2018 | 08:52 AM
Depends on the OEM wheel width, if it's a 7.5" a 225 would be the widest I'd run.
Old Aug 29, 2018 | 10:19 AM
ezbme's Avatar
ezbme
This would be a good choice. https://www.tirerack.com/tires/tires...omCompare1=yes The circumference will be extremely close to factory.
Old Aug 29, 2018 | 12:18 PM
Goonz's Avatar
Goonz
Sorry I forgot to state, the oem wheel is a 17x7
Old Aug 29, 2018 | 01:16 PM
slartibartfast's Avatar
slartibartfast
What blnewt said.
Old Aug 29, 2018 | 03:44 PM
bPChaos's Avatar
bPChaos
Why do you need wider tires? Looks? Additional traction? I'd say buying wider/stickier tires on a hybrid kinda defeats the purpose of economy, especially with tires that may make it ride more harshly.
Old Aug 29, 2018 | 04:07 PM
A 7" width really limits you, that 215 is about as much as I'd run. If you want a wider contact patch I'm afraid new wheels need to be in your shopping cart too
Old Aug 29, 2018 | 09:03 PM
Goonz's Avatar
Goonz
Understood! thanks again!
Old Aug 30, 2018 | 07:43 AM
stealthee's Avatar
stealthee
For what it is worth I ran 245's on my OEM 7" wide Lancer GTS rims last winter. Didn't have an issue.
If you want extra width the closest you'd get to OEM diameter would be 235/50/17.
Old Aug 30, 2018 | 12:08 PM
slartibartfast
The problem with a 235-width tire on a 7" wheel is sidewall flex. That'll cause sloppy turn-in and maybe a little wander.
davekin
Jul 3, 2015 12:38 PM
main_shoby
May 15, 2015 11:20 PM
