Help Sway bar replace question
I believe the X has the thickest front swaybar, but the thinnest rear. So a lot of people just replace the rear sway with one from a RWD since it is beefier.
But if you go aftermarket (Hotchkis), I personally would do both.
The Hotchkis set is thicker both front and rear. The OE sport rear bar coupled with the X front bar is better than stock and cost effective. Aftermarket bars are significantly better than stock. It just depends upon you wallet.
Stiffening only the front will give the car a tendency toward understeer. Stiffening only the rear, a tendency to oversteer. Stiffening both in a balanced manner will give the car more balanced cornering.
ClassyPump
Nov 2, 2017 07:46 PM
ReplicaR
Jun 21, 2017 02:51 PM
mjnoles1
Dec 18, 2015 10:19 PM
Genseven
Aug 11, 2010 05:30 PM
