Help Power Steering Rack
Old Sep 7, 2017 | 09:20 PM
TenSix's Avatar
TenSix
Power Steering Rack
On one of my multi-point inspections I was told that I had a power steering rack leak and the only way to solve this issue would be to replace the whole unit for a whopping $2100 including labor. I've held off on giving it anymore major attention other than checking the reservoir since I've had no issues with steering yet. Has anyone else had experience with this issue.
Old Sep 7, 2017 | 09:40 PM
hurleyguys's Avatar
hurleyguys
ya i have had mine seep for years. unless its really bad i wouldnt worry about it.
Old Sep 10, 2017 | 05:33 PM
Surfnazi's Avatar
Surfnazi
Do you see where it is leaking from
Old Sep 11, 2017 | 10:34 AM
TenSix's Avatar
TenSix
I haven't personally seen it myself in the engine bay nor on the ground and the reservoir seems to be at normal levels for now.
Old Sep 11, 2017 | 01:34 PM
AARONHL's Avatar
AARONHL
If you are not loosing fluid then don't worry about it...
Old Sep 11, 2017 | 03:46 PM
TenSix's Avatar
TenSix
Just wondering my friend that's all, thanks.
Old Sep 11, 2017 | 03:56 PM
AARONHL's Avatar
AARONHL
Just continue to check the fluid level and if you are losing fluid it's prob spilling under the car. Not really unsafe to drive but might just be hard to turn the wheel when the fluid gets real low
Old Sep 12, 2017 | 03:50 PM
Surfnazi's Avatar
Surfnazi
If no loss of fluid then it's not issue
Old Sep 12, 2017 | 06:08 PM
TenSix's Avatar
TenSix
Gotcha, thanks guys.
