SPC/Moog Camber Kit for cheap
Old Jun 13, 2017 | 09:29 PM
Scott McKenzie's Avatar
Scott McKenzie
Exclamation SPC/Moog Camber Kit for cheap
After doing some research I found out that SPC makes some of Moogs camber arms. In short the moog problem solver rear camber arms are the SPC camber kit. The arms turn buckle and bushings are stamped with SPC. Ordering through Amazon I was able to get my pair of arms for $94 shipped! Currently out of stock at this price but they should have more in within the month. I believe you can also get them from rockauto for a little bit more, Google the part # to find the best pricing.
Moog Part#: K100091(sedan only) / K100090(coupe)
Old Jun 13, 2017 | 10:29 PM
Is that per arm, or for the pair? If it's per arm that price is a bit higher than the SPC sets I've seen, if it's for the pair, you'll get this moved up to sticky status
Old Jun 13, 2017 | 10:41 PM
Scott McKenzie
Thats for the pair! Cheapest I'm seeing now is still ~$70 each
Old Jun 13, 2017 | 11:47 PM
Nice job Scott, let's stick this one up on the shelf then
Old Jun 16, 2017 | 10:14 AM
future62's Avatar
future62
Good to know!
Old Sep 28, 2017 | 10:16 AM
skrolz's Avatar
skrolz
I stumbled upon this thread, searched that model number for my coupe (K100090) and found one new on Amazon for $8.66 (price mistake?). Unfortunately, they only had one. I ordered it immediately. I'm looking for a second, but they are around $90/each everywhere else. I assume I can order an SPC for the other side. Do we know what part number the SPC equivalent is?
And thanks for this info!
Old Sep 28, 2017 | 01:01 PM
SPC #72260, here's an ebay source
SPC Alignment Rear Camber/Toe Kit for Nissan 370Z Infiniti G37 M35 Z34
Rockauto.com has the Moog for about the same price
MOOG K100090 Control Arm | RockAuto
If you go rockauto check this link for 5% off
https://www.retailmenot.com/view/rockauto.com?c=9020396
Old Sep 30, 2017 | 11:46 AM
Scott McKenzie
Honestly would like to know the difference between the coupe and the sedan arms. I ended up going with SPL because I needed the additional adjustment but I have a single sedan SPC arm if your interested will let it go for cheap.
Old Oct 2, 2017 | 10:06 AM
skrolz's Avatar
skrolz
As far as I understand it, they are different. A lot of vendors seem to be using the sedan set for the coupe pictures which makes it confusing. Thanks for the offer!
