Help H&R Springs - G37S Coupe springs on G37S Sedan
Old Jan 26, 2017 | 01:30 AM
ForceFedAP1's Avatar
ForceFedAP1
Has anyone ever used H&R lowering springs made for a G37S Coupe on a G37S Sedan? Would this work? Would I expect the sedan to be roughly the same height as the coupe with these springs or would it be higher/lower? Sorry for the newb questions, thanks in advance!
Old Jan 26, 2017 | 09:02 AM
All H&R springs will slam your G, if you want over 2" drop then they will suffice, but you will need front & rear camber arms, rear toe bolt kit. I was dropped about the same on B&G S2 springs and I'm up about a 1/2" higher on adjustable coilovers and much happier now.
FWIW the coupe springs on a sedan will give you a bit more drop in back IIRC.
I'd get Tein Basis Z coilovers, they will ride better and you can get the exact height you want, and for $500 shipped you can't beat it
