Help Tire size: Will it fit?
Old Jan 9, 2017 | 07:12 PM
BABrown's Avatar
BABrown
Car: 2009 G37S 6MT Coupe, staggered setup on 19" wheels
Currently riding:
Front: 245/40r19
Rear: 275/35r19
Will the following fit?
Front: 245/45r19
Rear: 275/40r19
appreciate any help
bb
Old Jan 9, 2017 | 07:41 PM
the93owner's Avatar
the93owner
Currently riding:
Front: 245/40r19
Rear: 275/35r19
Front: 245/45r19
Rear: 275/40r19
appreciate any help
bb
The new sizes are too tall. You need to keep the same overall diameter, or as close as possible, to avoid throwing off VDC or your speed sensor.
Old Jan 9, 2017 | 07:47 PM
BABrown's Avatar
BABrown
Thanks.
Tire rack says the following will be okay:
Front: 225/40r19
Rear: 285/35r19
Will that fit? Will 285 be too wide. I have stock 19" rims
Old Jan 9, 2017 | 08:12 PM
the93owner's Avatar
the93owner
Thanks.
Front: 225/40r19
Rear: 285/35r19
The 285 will be a little too wide, the widest you can safely go on the stock wheel is 275. However the variance between a 225 in front and 275 in the rear will probably not be ideal for handling. If you want a nice meaty setup, stick with your original setup of 245/40/19 and 275/35/19. Otherwise, the factory spec of 225/45/19 and 245/40/19 will be fine for daily driving.
Old Jan 9, 2017 | 09:07 PM
VenomGT9's Avatar
VenomGT9
need wider wheels for anything bigger than 275
stick with what you got until then
Old Jan 10, 2017 | 12:11 AM
Wangstas863's Avatar
Wangstas863
Hey guys I got same question , different size. My wheels are 20x9 +35 and 20x10.5 +42. I've been doing 245/35 and 275/30. Im trying to get some BFGoodrich tires, and nowhere can I find the rear size . Will 285/30 be ok in the rear? I'm on Air
Old Jan 10, 2017 | 12:20 AM
the93owner's Avatar
the93owner
285/30 will be fine
Old Jan 25, 2017 | 05:21 PM
Wangstas863
Is 285/35/20 no good?
Old Jan 25, 2017 | 06:29 PM
The 285/35 is over 4% taller than the 285/30 may cause issues w/ ABS & traction control
