Tire size help pls
Old Oct 21, 2016 | 09:58 PM
Peruviann's Avatar
Peruviann
Tire size help pls
I recently bought a 2013 g37 journey sedan. I just picked up the 19' 37s wheels with tire size 245/40r19 & 225/45 19. I want to get some eibach pro kit springs and add 15mm spacers in the rear, with 20mm spacers in the front.
Will I have any problems with the tire hitting my fenders?
Will the tire sizes be okay to run with the springs?
Old Oct 22, 2016 | 12:00 AM
Pretty common setup w/ that spacer size, I'd also pick up a rear camber/toe kit to go w/ the springs. Not sure what tire sizes he's running and he's got the 20s in back and the 15s in front~g37 coupes + 15mm spacers - G35Driver
Old Oct 22, 2016 | 12:10 AM
Peruviann's Avatar
Peruviann
any rear camber/ toe kit you recommend ? if i decided to go with coilovers. What would you recommend ?
Old Oct 22, 2016 | 08:54 AM
SPC is the most common setup around here and they work well. And for coilovers it's hard to beat the "bang for the buck" that the Tein Basis Z coilovers offer. They don't have damper adjusters but will get you to the height you want for just a couple hundred more than lowering springs. They used to be called just Tein Basis but have been replaced w/ the new name Basis Z, they used to be serviceable (you could send them to the factory to be rebuilt) but now are no longer serviceable, and the price dropped to about $500 shipped to reflect this. Here's a couple threads that should help. https://www.myg37.com/forums/brakes-...edan-6spd.html *****https://www.myg37.com/forums/brakes-...-template.html
Old Oct 25, 2016 | 12:09 PM
Peruviann's Avatar
Peruviann
so i been looking around and not sure on which one of these coilovers to order.
I will be mainly using the car to just drive around, drop off my kid to school, maybe try the track in the future.
what site would you recommend to get the camber and toe kits at ?
Tein GSP92-8UAS2 Street Basis Z Coilovers 07-08 Infiniti G35 08-16 Infiniti G37 09-16 Nissan 370Z
TEIN Flex Z Coilovers Infiniti G37 Coupe/Sedan (2008-2014) VSP92-C1AS3
Megan Racing EZ II Street Coilovers Infiniti G35/G37 Sedan (2007-2013) MR-CDK-IG082D-EZII
Old Oct 25, 2016 | 04:45 PM
I'd pick either of the Teins over the Megans, I have Megans and they've been ok for 50k miles but the Teins being a japan sourced product should have better quality control and for the price hard to beat IMO.
Old Oct 25, 2016 | 10:49 PM
Peruviann's Avatar
Peruviann
Just ordered the TEIN Flex Z for $750 not a bad deal. Now to save up money for some camber kits and toe kits. I also have an OEM chin Lip coming from infiniti.
