spring isolators on coilovers
Old Oct 12, 2016 | 12:14 PM
kdawg8526's Avatar
kdawg8526
i have kw v3's and i have the rears at highest setting according to the instructions 40mm of thread. but its still tucking tire has anyone ever tried spring isolators to raise it up a bit
Old Oct 12, 2016 | 06:04 PM
PNW_IPL's Avatar
PNW_IPL
also had that problem. ended up selling the coils. options I came across though was to purchase a taller spring to give you more adjustment
Old Oct 12, 2016 | 06:20 PM
kdawg8526's Avatar
kdawg8526
thanks ill try to look into that
Old Oct 12, 2016 | 06:27 PM
PNW_IPL's Avatar
PNW_IPL
swift makes coilover springs and you can get any spring rates you like. just need to measure the inner diameter of your current spring.
I'd say a 1in taller spring will be good.
Old Oct 12, 2016 | 10:53 PM
You can get the KW spring spacer, part #65030046 https://www.google.com/search?q=kw+s...h=576&dpr=1.09
Old Oct 13, 2016 | 01:59 AM
Presto's Avatar
Presto
do note i purchased these from ecstuning, they did not come as a pair. so you need to buy 2 pieces. i did not know this and had to pay shipping again for the 2nd one. have not installed them yet.
Old Oct 13, 2016 | 10:56 AM
kdawg8526's Avatar
kdawg8526
damn pretty expensive then
Old Oct 13, 2016 | 11:22 AM
PNW_IPL's Avatar
PNW_IPL
wish I knew about these before I ditched my coils
Old Oct 14, 2016 | 05:22 AM
Presto's Avatar
Presto
right now for a pair ecstuning is the cheapest as they have free shipping.
if you want to use a myg37.com supporting vendor use thmotorsports, they have a voucher code KWSUPERSALE but no free shipping.
Old Oct 14, 2016 | 06:27 PM
kdawg8526's Avatar
kdawg8526
so i saw this idea from another thread so for now i just took the oem top rubber cone spring mount and used it as a spacer on bottom and it helped alot now i have a 2 finger gap
https://www.myg37.com/forums/brakes-...-question.html
Old Oct 15, 2016 | 01:50 AM
HoldmyMouse's Avatar
HoldmyMouse
https://www.myg37.com/forums/private...g-spacers.html
Old Oct 15, 2016 | 07:16 AM
kdawg8526's Avatar
kdawg8526
^i saw that but he hasnt been replying lately
Old Oct 16, 2016 | 02:04 AM
Presto's Avatar
Presto
Any difference in ride quality or handling after doing the above?
Old Oct 16, 2016 | 12:35 PM
kdawg8526's Avatar
kdawg8526
ride feels a lil softer i havent been able to test handling because of the crappy weather
Old Oct 16, 2016 | 12:54 PM
Probably have a bit better NVH too, hopefully it works out well for you and would be a bargain fix
