Help Strut lower 19mm nut stripped
Old Aug 28, 2016 | 06:12 PM
Hdinh94092's Avatar
Hdinh94092
I was changing to coilover yesterday and the 19mm nut is rounded. I try using a smaller socket and hammer it in but not working. It's on there pretty good. What's another option to loosen this out? I finished all 3 except for my front passenger side. Front driver side was easy to take off But not this one.
Old Aug 28, 2016 | 06:27 PM
You should use an open end wrench on the back side of that bolt (don't remember the size, possibly a 21mm), but now w/ a rounded head you'll probably need an extractor socket, but still back it up w/ that open end wrench when using it. https://www.walmart.com/ip/Hanson-39...Piece/16494336
Old Aug 28, 2016 | 07:43 PM
Hdinh94092's Avatar
Hdinh94092
Yo
Yeah I think it's a 21mm. The driver side I didn't even use an open end wrench to hold it down to loosen the nut. I used my impact and it came off fine. Can I use the open end wrench and try to loosen that side and hold the nut with a socket that can fit
Old Aug 29, 2016 | 12:01 AM
You can give it a shot, but it's torqued down pretty good, over 100 ft lbs IIRC, doubt you'd get it from the back side.
Old Aug 29, 2016 | 06:21 PM
Hdinh94092's Avatar
Hdinh94092
ok i got the nut off good finally after breaking a cracking a breaker bar and had to buy another one. Problem now is i cant hit the bolt out.... like it slide through at the end but no matter how much i hit it, it still wont slide all the way out, like there some tension. can someone please help me? I am stuck with just one front passenger side that need to be done. here are some pic...
Its like its not straight.. and have tension on the suspension. How can i hit it out? I use a screw driver and hammer and wack wack wack, nothing and still stuck like this.
Driver side came off easily.
But here are the passenger side look like...its not even rusty. only has 29k miles on the car.
Old Aug 29, 2016 | 09:22 PM
Hdinh94092's Avatar
Hdinh94092
Got it done
I got it done! I had to loosen the sway bar end link nut on the driver side and passenger side to release the tension!
Old Aug 30, 2016 | 12:30 AM
Yeah, you didn't mention you still had the end link connected to the sway, you should remove that first, you can bind up that ball joint and even snap them. Hopefully your end links are still ok. Glad you got it removed.
Old Aug 30, 2016 | 11:31 AM
PNW_IPL's Avatar
PNW_IPL
That caused your issues. The endlinks has alot of tension
Old Jul 3, 2017 | 12:06 AM
G37zus's Avatar
G37zus
Sorry to reopen an old thread but ..
Sorry to reopen this one but I've run into the same issue with the 19mm. Where'd you get your replacement nut from? I have my new coilovers in and everything put back except for the 19mm nut I stripped.
Thanks!
Old Jul 3, 2017 | 08:30 AM
Might get lucky and the dealer will have one, try Nissan dealer too.
Old Jul 3, 2017 | 02:28 PM
G37zus's Avatar
G37zus
Thanks! I tried the Nissan and Infiniti dealers in my area and they don't have a replacement on hand so I ordered one. ðŸ‘
Dough1397
Aug 13, 2019 03:33 PM
defektion
Sep 25, 2017 02:58 AM
Upscale Speed
May 15, 2016 07:55 PM
pureoptic
May 1, 2016 03:53 AM
Strongblood8
Mar 25, 2016 06:45 AM
