40 series on front by mistake ...
Old Aug 14, 2016 | 08:37 PM
pricha00's Avatar
pricha00
Just got full set of staggered BF Goodrich Sport Comp 2 for my coupe. In error the shop put on 225/40/19 instead of the OEM 225/45/19. The rears are the correct 245/40/19. The car drives OK but being stock ride height the space between the tire and front fender has now grown even larger and looks a little goofy. Do I have the OEM size put on or just lower the whole car, though I doubt I would ever consider any more than a real mild drop.
Pat
Old Aug 14, 2016 | 09:00 PM
micafd3s's Avatar
micafd3s
have them put the oe size back.. if you want to keep that profile and lower her.. at least go a size wider to keep it within spec..
or swap the rear tires to the front and go wider in the rear..
Old Aug 14, 2016 | 09:09 PM
pricha00's Avatar
pricha00
Thanks it was the shops error so while its an hour drive away, I will take their offer to swap in OEM. I doubt they would want to swap all four tires again if I moved the rears to the front and went like 275 or something on back. Plus at only 8.5 inches aren't the front wheels too narrow for a 245 anyways.
Pat
Old Aug 14, 2016 | 09:14 PM
G37xhibeet's Avatar
G37xhibeet
245 is a good tire width for an 8.5" wheel. I'm running 245 on 8.5" in front and 285 on 10" in the rear.
Old Aug 14, 2016 | 09:41 PM
pricha00's Avatar
pricha00
I am keeping the OEM 19 inch wheels for now, so 285 I think a little extreme for a 9 inch wheel. That certainly looks terrific from behind I am sure.
Pat
xstarpro
Apr 13, 2016 09:06 PM
Apr 12, 2016 03:23 PM
Diaz90
Mar 21, 2016 11:41 PM
