Help Can you install 380mm rotor w/stock Akebono
Old May 28, 2016 | 03:13 PM
DJMAC's Avatar
DJMAC
Hello,
Slowly installing bigger brake setup for some track time. I have an option to get some 380mm rotors now before the 6 pot calipers come in August. Question is can I install the rotors and use my current stock Akebono calipers in the meantime?
Old May 28, 2016 | 11:28 PM
Originally Posted by DJMAC
Hello,
You'd have to fabricate a bracket to remount the caliper further from it's current mount point, this assumes the rotors are the same thickness. And you probably wouldn't be able to slide the caliper all the way down onto the rotor and get 100% pad coverage since they were designed for 355mm rotors. You'd probably have a portion of the top of the pad that wouldn't be scrubbing the rotor.
Old May 29, 2016 | 04:17 PM
DJMAC's Avatar
DJMAC
Rotor
Thank you, I was wondering about the mounts. Fabrication is not in my skillset. I will just wait till it's all ready to go.
Mac
Old May 29, 2016 | 04:37 PM
evil-G-nius's Avatar
evil-G-nius
Power slot use to have brackets for this very thing. I am not 100% sure it comes by itself though. Check their site for relocation brackets
Old May 29, 2016 | 05:13 PM
slartibartfast's Avatar
slartibartfast
Have you though about wheel clearance? You're moving the caliper radially out an inch, is there that much existing clearance with the barrel?
andrewk523
May 18, 2016 04:39 PM
Upscale Speed
May 15, 2016 07:55 PM
Moe_G37x
May 6, 2016 10:41 AM
Moe_G37x
May 5, 2016 01:27 PM
jq604
May 3, 2016 09:36 PM
