Tire wear/alignment question
I have a 2012 G37xS sedan that I just bought used. It has 21,000 miles on the original tires. No accidents. The car drives straight even when hitting the brakes. But, all 4 tires have noticeable increased wear on the inner shoulders. Otherwise the wear is even. Is this an alignment issue? Camber? What is adjustable when they do an alignment? The car is completely stock.
Gosh, I need to write up the toilet paper roll experiment to to illustrate why camber is not an issue. Maybe I can find it with Google...
I can't find the old visual tool. But the gist is to take a roll of toilet paper on an axle of some sort that allows attitude changes of the roll to the ground.
Lay it flat and roll perpendicular to the axle -- no visible wear. Toe and camber = zero.
Apply a small angle to the axle and roll in the original direction such that the entire roll surface touches the ground -- you'll see the paper exhibits wear and maybe some paper is ground off but the wear is even. Zero camber but +- toe.
Tilt one end up and roll perpendicular to the axle -- slight wear on the paper touching the ground. Camber +- but toe = zero.
Last condition is to tilt the roll and angle axle to direction of roll -- camber +- and toe +-. You see the greatest wear on the toilet paper at this condition.
It's possible the previous owner lowered the suspension, drove it without camber/toe kits then returned it back to stock to trade it in, this would account for the poor inner tread wear while the car still drives ok.
I thought toe in would cause more of a feathering? I don't think the previous owner lowered it but there is no way to be sure. Should I get the alignment done at Infiniti/Nissan or will I be ok going somewhere else?
Well, no one can align for a camber issue as front camber is fixed unless you buy and install adjustable front upper control arms. Only toe is adjustable up front. Infiniti is as good as anyone else, though searching out a shop that can give "performance" alignments is better as they'll deviate from OEM specs if you ask.
Since you stated that all four tires had heavy inner tread wear it sounds like it may have been lowered previously. If it was only one tire or a pair of tires then something out of align on a stock suspension sounds reasonable, but all four seems likely that it was dropped. There's plenty on this site that lower their cars and return them to stock on a lease return or trade in.
There is still some tread but I'm going to replace all 4 tires within the next month. I'll get an alignment when the new tires are mounted/balanced. Is there any way to tell if it was lowered? I can ask the place who does the alignment to look for signs.
When you get it aligned they should give you a before & after setting sheet. If the before alignment is ok, and no adjustment needed then I would say that it was previously lowered, but again, it may have been realigned at the dealer if they noticed the tire wear so
Thanks all for the replies. I guess I'll get the alignment checked when I put on new tires and report back the results. On a side note, my steering wheel shakes and vibrates a lot when hard braking from higher speeds. The car only has 21,000 miles and the pads have a good amount remaining. I'm guessing it is "warped rotors"(ie. uneven deposits on the rotors). I was going to get the rotors resurfaced to even them out. I've read it is best to use an on car lathe. Is this correct? Do I need to get new pads if I have the rotors resurfaced?
Try a few hard slow downs from 60mph down to 10mph, about 5-6x while never letting the car fully stop, this may clean some high spots if it is just pad deposits.
And one other thing, the lower front shock mount bolt (the big 19mm one) IIRC has a paint swab across it, so if it's ever been loosened you should be able to tell.
G/L
