Tire wear/alignment question
Old May 23, 2016 | 03:57 PM
rlb's Avatar
rlb
Try a few hard slow downs from 60mph down to 10mph, about 5-6x while never letting the car fully stop, this may clean some high spots if it is just pad deposits.
And one other thing, the lower front shock mount bolt (the big 19mm one) IIRC has a paint swab across it, so if it's ever been loosened you should be able to tell.
G/L
I did the hard slow down rebedding. It helped a little but I still have the steering wheel shake. I don't feel any deposits on the rotor. Would spraying/wiping with brake cleaner help? I could replace the rotors but I read that even new ones can have runout variations and that the only way to truly avoid that is with an on car lathe. Pep Boys charges like $80 per axle to do this. Any thoughts on that?
Old May 23, 2016 | 05:02 PM
Yes, you could try brake cleaner wiped down w/a Scotchbrite pad, I've done that before and it will help if it is a pad deposit issue.
Old May 29, 2016 | 04:52 PM
Surfnazi's Avatar
Surfnazi
Could always take off pads and resurface them a little as well as the rotors
g37nightrider
May 23, 2016 01:15 AM
JP_Chi
Apr 14, 2016 07:53 PM
Finestcut
Mar 30, 2016 10:30 PM
iCrap
Mar 17, 2016 11:59 PM
