Nismo Suspension?
Old Mar 24, 2016 | 12:17 PM
xmajd92's Avatar
xmajd92
Nismo Suspension?
I currently have Eibach springs and the bounciness is getting old after almost 6 months now. I live in Houston so those who know, the roads suck in a lot of areas. I need some coilovers and I'm aware of BC, KW, Tein, etc. A friend of mine thought of Nismo coilovers as they are "track proven" but does anybody know of any G's running this?
I also know of someone who drives a g35 with pretty much every aftermarket nismo part on his. While I'm waiting on a reply from him I also wanted to know if anybody knows the compatible part number for the G37.
Old Mar 24, 2016 | 02:35 PM
HoldmyMouse's Avatar
HoldmyMouse
Are your shocks blown? They should ride pretty close to stock but firmer. I don't think they have Nismo coilovers for V36.
Old Mar 24, 2016 | 04:25 PM
xmajd92's Avatar
xmajd92
I don't think they're blown. And I just found out they don't make for v36.
Old Mar 24, 2016 | 06:50 PM
slartibartfast's Avatar
slartibartfast
Check the sedan RWD coil-over sticky in the suspension forum for a fairly comprehensive list. Despite entitled "sedan", almost all are actually built for the coupe.
Old Mar 24, 2016 | 07:12 PM
Ape Factory's Avatar
Ape Factory
If you want OEM, look at the IPL shocks. They'll be valves more aggressively. Just remember the G is a good deal heavier than the 370 and the spring rates and shock calving may be (should be) different. Ultimately, any lowering spring will take an OEM Shock out of its preferred stroke and lead to premature wear.
Old Mar 27, 2016 | 05:31 AM
xmajd92's Avatar
xmajd92
Decided to buy D2 RS Series coilovers. I'll see how they are personally. I can barely find information on these for the G so I guess I'll be a guinea pig.
Old Mar 27, 2016 | 10:15 AM
Should be similar to the Megan/BC/KSport sets, should work well for a daily driver.
Old Apr 19, 2016 | 05:48 AM
RogerSmith's Avatar
RogerSmith
How do the IPL shocks differ compared to stock on an S? Does it sit lower?
Old Apr 19, 2016 | 09:07 AM
Ape Factory
They're matched to the IPL springs so they'd be valved differently. The IPL suspension is a bit more taunt than the S overall but the ride height is identical. Will not lower the car. If you're not trying to lower the car, the IPL setup is going to be better than the Nismo 370Z suspension as it's specifically for the G, its increased weight, and length.
Old Apr 19, 2016 | 09:40 AM
Lego_Maniac's Avatar
Lego_Maniac
Koni yellows fit the RWD cars
Do you want adjustable height, dampers, or both?
Old Apr 27, 2016 | 08:41 PM
grojas112's Avatar
grojas112
Will the koni yellows fit an X sedan
Old Apr 27, 2016 | 08:53 PM
Lego_Maniac
Rears, yes, fronts, no.
You might be able to swap the Koni guts into the X shock bodies like the WRX/STi guys do, but IDK
Ape Factory
Jul 1, 2017 10:29 PM
FPVJAY
South
13
Mar 26, 2016 10:29 AM
Detailed Image
Lighting/Cleaning Products
Mar 23, 2016 04:14 PM
69GTOFarm
G37 Convertible
Mar 23, 2016 02:52 PM
iCrap
Mar 17, 2016 11:59 PM
