Another fact that comes to mind is weight of each corner. I think it was in one of motor trend's road tests on this car where they weighed each corner.
One other thing that happens sometimes too, is if one set of wheels has hub rings and the ring stays behind and you install a new wheel it can keep it from meeting the hub properly.
Stock Infiniti wheels use hub centric rings?
I thought they were all lug centric
I think it could possibly be because the rear passenger side is slightly higher.
I should measure the center to fender distance, but for now my three fingers barely fit on the driver side, but easily fit on the passenger side.
OEM won't be, but I wasn't sure if your winter tires were aftermarket or not. If you went OEM to OEM there shouldn't be any rings. If it's really bothering you it only takes a couple minutes to take a wheel off to make sure there's nothing blocking it and put it back on.
OEM wheels are hubcentric, the OEM mag style lug nuts w/ washers get it very close and the 66.1mm wheel bore and matching hub flange do the final centering.
