19x11 +18 - G-Force Comp 2 - 275/35/19 - They must run big because I was hoping they would stretch if I went down to 275 for when it's lowered but the side wall is practically flush. They are gonna rub like a couple of virgin teenagers on homecoming..
This rear wheel is 19x11 +18? i have the same size wheel and thought it would poke out way more even though it is stock height. looks great!
I'm shocked that's an 11" wheel with a +18 offset! I'm absolutely flush at -1.5 degrees camber on a 9.5" rim, -25mm offset. That wheel should poke out another 26mm or a bit over an inch further. What sort of camber are you running?
