rear springs?
rear springs?
Does anyone make a higher rate spring for the rear???
Stock height is ok, but the back dips down so much with hard throttle of if car is loaded. Just want to keep it up a little. I know on my van I can get the monroe coil overs, basically shocks with helper springs, but they dont make them for our car... so I figured a spring with a higher rate should do the trick.
I have a G37 sedan and to my taste stock rear springs were too soft even for regular highway lane changing. there are several options for stiffer springs depending on your application, not sure which one will give you least drop :/ swift springs?
I believe that info is posted somewhere here on the forum, but I don't know where off the top of my head and I'm not in a position to search for it right now. You can give it a try though. Or maybe some kind soul who knows will chime in to help you.
jdhilditch
Mar 8, 2016 05:18 AM
smitty37g
Mar 4, 2016 07:08 AM
