New (?) SPC front camber arm - 73005
Old Mar 3, 2016 | 12:12 PM
teknolust72's Avatar
teknolust72
Just noticed this part number on SPC's website, and it's a major design change and improvement over their other offerings. Price is higher though, but it seems like a great solution. Anyone have any experience with this yet?
http://www.spcalignment.com/componen...AFrom&to=USATo
Old Mar 3, 2016 | 04:38 PM
AARONHL's Avatar
AARONHL
I like that design BUT have fun adjusting those with equal caster on both sides
http://www.ebay.com/itm/SPC-73005-Ad...-/311531591742
Old Mar 3, 2016 | 10:13 PM
jfisher's Avatar
jfisher
If that's what you're willing to spend I'd 100% pay the extra $200 and get the SPL's. These SPC arms don't solve the "adjustable" on the car problem like the SPL's do.
Old Mar 12, 2016 | 03:25 PM
TVPostSound's Avatar
TVPostSound
SPC 73005 Adjustable Control Arms Pair Fit Infiniti G37 16 Fit Nissan 370Z | eBay
Caster adjustment would be far easier with those, than the old design.
Equal turns= Camber
Turn 1 only= camber and caster.
Equal opposite turns = Caster not camber
Old Mar 12, 2016 | 05:49 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
You couldn't pay me to put those on my car!! I have SPL arms..
Old Mar 22, 2016 | 10:33 PM
AARONHL's Avatar
AARONHL
Equal turns= Camber
Since there is no preset caster selection like the old ones (my preference), not only will you be raising and lowering your car to adjust the camber but the caster is interconnected and has to be adjusted at the same time AND both sides need to be exact...have fun with that!!!
Maybe if you could match the arms to the OEM upper control arm to get a starting point it would help out
Old Mar 22, 2016 | 11:46 PM
RadioFlyer's Avatar
RadioFlyer
The design looks good! All you would have to do is turn the turnbuckles to adjust. At least you don't have to uninstall them like some others. I also appreciate the rubber bushings and sealed ball joint. I'd run these if I were in the market.
Old Mar 23, 2016 | 12:50 PM
jujubii's Avatar
jujubii
This is extremely intriguing
While I do have the SPL upper control arms, I acknowledge that there may be some design flaws. When I was in the market for UCA's, SPLs were the superior of 3 options (older SPC version and kinetix). Given the SPC has a bit of a poor reputation, I would be a bit wary. Design doesn't throw any flags; I am unsure of worksmanship.
See post #43 here: SPL Parts Prototype GT-R Adjustable Front Control Arms - Part 1 (install) - Page 3 - Suspension & Tires - GT-R Life
edit: just noted the pricey price
Old Mar 23, 2016 | 01:59 PM
m3clubracer's Avatar
m3clubracer
I agree totally.
Old Mar 26, 2016 | 03:05 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
We've had great luck with their products thus far.
Old Mar 29, 2016 | 10:36 AM
TVPostSound
Its a no brainer.
I have the SPL, it's the same manner of adjustment.
Once camber is set by equally turning both sides in the same direction, caster can be adjusted by turning equally in opposite directions, while maintaining camber.
If one is knowledgeable, one can actually adjust both at the same time.
Stop being chicken little, its an improvement.
Old Aug 17, 2016 | 01:56 PM
jfisher's Avatar
jfisher
Anyone used these yet?
Old Aug 21, 2016 | 02:36 AM
Ape Factory's Avatar
Ape Factory
There's also the Voodoo arms but from what I've read, the SPL's have more adjustment range and no interference issues. The Voodoos look great though.
https://conceptzperformance.com/vood...00_p_27005.php
Old Aug 21, 2016 | 11:59 AM
Don't recall the member name but someone is using their rear arms and look to be a nice option.
Those Front UCAs look pretty nice.
Old Aug 22, 2016 | 07:48 AM
jfisher's Avatar
jfisher
I had heard of those, but didn't know they were in the sub $700 price range. Hmm. Those look to be very well made.
