Stance coils for Z same as G ?
Old Jan 23, 2016 | 08:45 PM
Phx-G37s's Avatar
Phx-G37s
So are the stance ss coilover the same for z as g?
They have Em on Amazon for the z but not for g. I have 800 credit on Amazon.
The part number is st-z34-sso
I've seen this part number on other sight that said g/z but I wanted to be sure before I order them.
I wonder if spring rates are same? It says 13/5 which seems like it's inline w g ones, but I have seen 13/8 in another place.
I want the oem style a little more, maybe I can ask seller if they have oem type.
I was going to purchase the new tein flex z for lil less, but Amazon says out of stock and no news on when have more. It's same as street flex, just sealed shock so only cost 800-900. Since they not there, figure stance are good alternative, but I wanted oem for less stress on chassis and chance of noise.
Old Jan 23, 2016 | 09:29 PM
Spring rates are listed as 12/11, and yes the part #s are the same for the Z and the G.
Check these two links
https://conceptzperformance.com/stan...36_p_13991.php
https://conceptzperformance.com/stan...34_p_11894.php
Might look into these two true coilover setups as well, the OEM rear coil setup seems more noise prone, but there is less concentrated load on the mounts. Shouldn't be a problem for a daily driver though.
https://conceptzperformance.com/stan...36_p_13990.php
Old Jan 24, 2016 | 02:50 AM
Phx-G37s's Avatar
Phx-G37s
Ahh ok so the st-z34-sso is oem type. St-z34-ss is true type.
I got a response from vendor on Amazon he said yes it is. Also he will give me the oem type same price, even tho stance usually charges a lil more.
I had asked him about the new Tein flex z as well, and he has it too, but he said that he recommends stance over those. Idk if it's because they cost more or really because they are better haha. If you think about it flex z are same as street flex which cost even more than stance, but would be getting for 8-900.
Lol I'm so indecisive when comes to things like this, so many things to consider. Wish I could try them both out, but no one I know of has either or anyone that has even owned both on the forums to tell me the difference.
Another factor I need to look up is drop heights. I am going for conservative drop. Only like 1-1.5 front and .5-.75 rear if possible. I know teins have min drop of 1/.6. Dunno bout stance .
Old Jan 24, 2016 | 06:08 PM
JM Auto Racing's Avatar
JM Auto Racing
MYG37.COM Sponsor
The Z and G do use the same coilovers even though the G is heavier. We can get you the stance coilovers with a slightly higher rate to compensate the difference. That is usually what happens when we place orders for G coilovers.
JM Auto Racing
Brakes/Suspension
412
Nov 28, 2022 10:30 AM
TastefullyDoneG
Dec 18, 2016 10:04 PM
G37xsfun
Dec 20, 2015 06:42 PM
98intrigue
Nov 17, 2011 10:47 PM
