Eibach Owners...Clunking sounds?
Old Oct 31, 2015 | 01:14 AM
evil-G-nius's Avatar
evil-G-nius
I am considering a set but I have been told that they are noisy and make clunkign noises when you hit bumps. I had Eibachs on my Galant and never heard a peep. So I am wondering if anyone has had any "clunking" noises from their setup. If not, did you get new shocks or roll with stock shocks?
Old Nov 1, 2015 | 10:47 AM
VQCrew's Avatar
VQCrew
When I had Eibachs I didn't have any noises or any clunking either. I had them with the stock shocks too.
Old Nov 1, 2015 | 12:13 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Eibach makes many suspension products. Which are you referring to??
Old Nov 1, 2015 | 02:02 PM
Could be coil binding that you're referring to, here's a couple info posts
Megan Racing
Fix any spring binding with my quick fix DIY!
Old Nov 2, 2015 | 11:51 AM
evil-G-nius
Just a pro kit lowering springs
Megan Racing
This might be what I am looking for. I don't think that it would be an issue, but you know once someone puts a bug in your ear you have to check everything again to make sure you didnt miss anything! I'd hate to get these springs and then everytime I hit a bump have to hear some damn noise...might drive me nuts. Thanx guys
Old Nov 3, 2015 | 09:24 PM
HoldmyMouse's Avatar
HoldmyMouse
Not sure what can be the problem because there should not be any noise at all (considering everything else stock). Only thing I can say is to make sure it was installed correctly and everything tightened to spec.
Old Nov 4, 2015 | 12:49 PM
m3clubracer's Avatar
m3clubracer
No noises with ~4k miles on them.
Old Nov 4, 2015 | 01:04 PM
MaQG37's Avatar
MaQG37
Is it coming from the rear? Check to see if the strut top nut is tight and the rubber gasket that sits between the strut and chassis is present. Those two things were causing a clunking for me in the rear. And, are sure the two top nuts holding the struts front and rear are torqued to spec. The front strut nuts seem to back out once the car had settled.
Old Nov 4, 2015 | 03:28 PM
Ryne's Avatar
Ryne
The Steering Wheel Guy
Many miles, no noises.
Old Nov 8, 2015 | 11:17 PM
evil-G-nius
I dont have them yet. Iwas just curious because of something I heard from someone else. I too think that if they had noise, they were not installed properly. My last car that had em never made a sound either so I am confident that when I get them they will be fine. Thanks for the info guys
nbast
Mar 25, 2016 01:30 PM
gogetemG
Dec 8, 2015 12:31 AM
1BADQ60S
Oct 30, 2015 02:45 AM
gogetemG
Oct 29, 2015 02:23 AM
MaQG37
Oct 25, 2015 09:57 PM
