I need your help
Old Nov 4, 2015 | 06:05 PM
Mido-g37's Avatar
Mido-g37
Originally Posted by crookncastle
sounds like the caliper piston seals may be leaking fluid pressure causing the low pedal. check to see if those piston seals are available to be replaced by themselves. otherwise you may need to buy a complete caliper. lesson learned the hard way, if you don't know what you are doing keep your hands off it.
The piston seals are good, but I need the seal that goes between the two parts of the caliper, which was damaged. Yeah this is the most expensive lesson I have learned so far
Old Nov 4, 2015 | 06:11 PM
Mido-g37's Avatar
Mido-g37
Originally Posted by nelledge
Sounds like you're not done bleeding the system. Do it again sequentially following the steps outlined in the FSM. Bleeding hydraulic systems can take a lot of patience, especially when the hydraulic system has been opened.
Also, verify you don't have any existing leaks. Look very closely at the piston seals on the calipers. They may have been damaged if you disassembled them.
Your suggestion of checking the seals was really helpful and that saved me a lot of money. I really appreciate your help.
Old Nov 4, 2015 | 09:18 PM
HoldmyMouse's Avatar
HoldmyMouse
Check with z1 who is our vendor
https://www.z1motorsports.com/brakes...it-p-6891.html
Old Nov 6, 2015 | 10:47 PM
Mido-g37's Avatar
Mido-g37
Originally Posted by HoldmyMouse
I checked with them, they sell it with their rebuild kit, thank you so much
TheIvoryG
Sep 23, 2015 02:06 AM
beng37s
Intake and Exhaust
Sep 19, 2015 01:32 PM
joshferbs
Sep 9, 2015 08:53 PM
