Help Which brake pad? Too many options
I was told the brake on my G needs to be replaced. I have done a lot of searching and reading. The most mentioned are Centric Posi-Quiet, Akebono ProAct and StopTech Street Pads. I decided to go for Centric Posi-Quiet.
Went to rockauto.com and I was surprised to see so many options. I don't race or do track so I figure daily driver should be enough? or should I go for High Performance/Heavy Duty?
I have a 2011 G37X sedan. Which one I should get? These two below?
CENTRIC Part # 10508880 Posi-Quiet Ceramic w/Shims and Hardware
Front; AWD; Sedan; X Model; 320mm Front Disc & 307mm Rear Disc
CENTRIC Part # 10509051 Posi-Quiet Ceramic w/Shims and hardware-P
Rear; AWD; Sedan; X Model; 320mm Front Disc & 307mm Rear Disc
I want to make sure before I order. Thanks.
Front; AWD; Sedan; X Model; 320mm Front Disc & 307mm Rear DiscCENTRIC Part # 10509051 Posi-Quiet Ceramic w/Shims and hardware-P
Rear; AWD; Sedan; X Model; 320mm Front Disc & 307mm Rear DiscI want to make sure before I order. Thanks.
