Lowering & Wheels
Old Jun 17, 2015 | 10:12 PM
amciner28's Avatar
amciner28
Lowering & Wheels
Hey everyone, so I have seen this discussed but the last discussion seemed to be in 2010 so I figured I would bring this up again. I am ready to do the last "mod" to my car which is to get rid of the horrible 17" wheels that came with the car.
I'm all set with the wheels, or at least I know what to get, but the lowering part is the issue. I don't want to lower the car, but because I have the X sedan it looks like a truck with a lift kit. Apparently, Eibach only makes lowering springs for the X COUPE and the non-X sedan.
My question is: why would the sedan springs not be cleared for the X? Apparently others have used them without a problem, but then why does the description exclude AWD? Also, if the kit costs $350 brand new, how much in labor can I expect to pay a reputable shop (MA)?
Thanks in advance!!
Old Jun 17, 2015 | 10:15 PM
amciner28's Avatar
amciner28
Edit: apparently I can get it for $250 on Tire Rack
Also, if I plan on doing this at the same time I get my new wheels with a full alignment, I don't need to worry about getting a camber kit or anything, right?
Old Jun 17, 2015 | 10:55 PM
Here's a thread that may be of help, they're Eibach G35X Sedan springs and they seem to offer a nice drop, as far as needing camber kits, probably in the rear at least
https://www.myg37.com/forums/g37-sed...-it-works.html
You can also go w/ Swift Springs, they make an AWD sedan version as does Tanabe, but the Tanabes drop a bit more in back so here's a thread about that too
My 09 G37xS (AWD) Lowered on Tanabe - Droopy Bum fix too!(PICS) - G35Driver
Old Jun 18, 2015 | 10:26 PM
amciner28's Avatar
amciner28
good to know, thanks! given that it's basically impossible to find a square set of 19's, i'm worried I'll have to go aftermarket. Do you know of any wheels that fit the Infiniti center caps? I want the car to look as stock as possible.
Old Jun 19, 2015 | 12:15 AM
If you can't locate the coupe 19s in a square set (sometimes they turn up in the classifieds) you could look for Infiniti 19" wheels from the M sedan, they look nice and are square. Also Nissan wheels use the same center cap, might be some Maxima 19s
Old Jun 21, 2015 | 06:18 AM
roxx's Avatar
roxx
This is an X with 19x8.5 Infiniti rims and Tanabe NF210 springs. No cam kit installed yet as only rear is out of spec and barely, I like the slight slam look... If you're looking for a year round option somewhere with mediocre to bad roads like me, this might be a good suggestion since it reduces wheel gap but doesn't leave you scraping.
Old Jun 21, 2015 | 09:21 AM
amciner28's Avatar
amciner28
damn that looks pretty good and i also just got a set of M 19s... how much did it cost you to do that?
Old Jun 21, 2015 | 10:59 AM
roxx's Avatar
roxx
Thanks man, I picked up the springs for $180 and had my local dealer install them, so add the time of labor. Worth it to kill the AWD gap though.
Old Jun 21, 2015 | 12:28 PM
amciner28's Avatar
amciner28
awesome, did you go to the infiniti deal or a local garage? How much did they charge? I've been having a hard time getting a read on if this is something that a garage can do in an hour or if it takes 5.
Old Jun 21, 2015 | 05:21 PM
roxx's Avatar
roxx
I went to Infiniti and I had rims mounted on tires and had them installed with the springs, had a squeaky belt looked at, changed the oil and oil filter and also got it waxed and buffed so it took right under 10 hours at $80 an hour but I think that depends on the dealer.
Ricio1991
Oct 17, 2018 11:24 PM
james6980
Oct 9, 2015 01:28 PM
Broski28
Aug 26, 2015 07:42 PM
