G37xS suspension vs Q50S awd
Old Jun 5, 2015 | 05:05 PM
tsneaux's Avatar
tsneaux
How different are the two suspension systems? Club member has a Q50S awd and swift has been working with him to develop springs. He has a free set now that they've changed things up a little but the question is will they work on my '10 G37xS?
Old Jun 6, 2015 | 09:33 AM
Motoboat's Avatar
Motoboat
What are you looking to accomplish? Lower, improve handling? Your idea is to swap in his swift springs? If they are doing r&d to match springs to a Q50, it probably does have a different suspension set up. Although it might be really close, there is a real possibility it won't work. You can try and get the part numbers off his springs and match them to the swift g37 springs and see if they are the same. In the end, swift springs aren't very expensive and you can probably pick up a used pair in the classified section for cheap 👍🏻good luck
Old Jun 6, 2015 | 11:22 AM
eljoker's Avatar
eljoker
The rear of all Q50s is now a single unit shock and spring like the M37/56/Q70s are. Front suspension I believe is still off the G.
Old Jun 6, 2015 | 04:06 PM
tsneaux's Avatar
tsneaux
Yep, after further investigation thats what I learned. Was just hoping to get a free set of new springs if they would work, appears that isnt going to be the case.
m1cha3l
Buying & Leasing
41
Mar 9, 2019 12:56 PM
bmfrancis007
Oct 1, 2015 06:52 PM
johnadlertech
Sep 14, 2015 12:18 PM
EnYcee-G
Sep 3, 2015 04:35 PM
MattCica
Intake and Exhaust
Aug 20, 2015 11:08 PM
