New Koni Yellows don't rebound at the same rate, normal??
Old Mar 13, 2015 | 02:34 AM
antirice's Avatar
antirice
I bought a new set of Koni yellows and I noticed one of them (rear) rebounds noticeably slower than the other 3. I made sure all 4 are set at the same softest setting (factory default). All 4 shocks compress normally with similar resistance. Should I be concern about the slow rebounding one?
Sorry for making another thread about the Koni, don't have much knowledge on suspension.
P.S. Regarding the slow rebounding one, I noticed if I lay the shock flat on the floor, as opposed to putting it upright like on the car, it will rebound at a much faster speed, similar to the other 3 at upright position
Old Mar 13, 2015 | 06:44 AM
Lego_Maniac's Avatar
Lego_Maniac
I didn't compare the rebound amongst the shocks. My advice would be to call Koni and talk to someone in customer service.
Old Mar 13, 2015 | 07:18 AM
SwissCheeseHead's Avatar
SwissCheeseHead
Yes, this is normal. I installed these in my BMW and experienced the same thing. I called them and they said that once you break them in, they will all normalize and have the same rebound rates. I never took them off to verify but the car behaves as I would expect on the road. Hope that helps.
Old Mar 13, 2015 | 01:31 PM
antirice's Avatar
antirice
I emailed Koni and got a response within 20 mins. Impressive.
Here's what they said:
Thank you for contacting us here at KONI shocks. The rate at which the shocks extends on its own is no reflection on the shocks damping force or function. The gas pressure inside the damper has no effect on the shocks valving, as the force is created at the piston and valve shim stack and foot valve. It is not uncommon for a shocks to rebound at different rates due to initial friction of the guide seal, and internal friction of the new parts.
Mason O’Hara
KONI North America
1961A International Way
Hebron, Ky. 41048
859 488-0324
www.koni-na.com
www.koniracing.com
www.konirv.com
Old Mar 13, 2015 | 01:45 PM
Ryne's Avatar
Ryne
The Steering Wheel Guy
Originally Posted by antirice
I emailed Koni and got a response within 20 mins. Impressive. Here's what they said: Thank you for contacting us here at KONI shocks. The rate at which the shocks extends on its own is no reflection on the shocks damping force or function. The gas pressure inside the damper has no effect on the shocks valving, as the force is created at the piston and valve shim stack and foot valve. It is not uncommon for a shocks to rebound at different rates due to initial friction of the guide seal, and internal friction of the new parts. Mason O’Hara KONI North America 1961A International Way Hebron, Ky. 41048 859 488-0324 www.koni-na.com www.koniracing.com www.konirv.com
Nice and quick response. I suspect they are asked that question a lot and have a prefabbed response. Always nice to confirm and inform everyone else for the future.
Old Mar 13, 2015 | 01:57 PM
Lego_Maniac
You probably know this, but make sure you pay attention to how you assemble the lower spring pearch on the front shocks. It's possible to mount them upside down which will raise the front end.
superjoey
31
Mar 22, 2023 11:56 PM
ladydriveng37
Oct 11, 2015 05:23 AM
maybeg37
Sep 8, 2015 02:33 PM
