Help Wheel Fitment Question
Found some Vossen rims for cheap and the only available fitment was 20 by 9 +20 & 20 by 10.5 +25. Im currently lowered on eibach springs and was wondering If i would have any issues with this setup?
Coupe you could squeeze those in w/ narrower tires, a sedan would require heavy camber, very stretched tires, and probably some rear fender pulling.
thanks for the replies & im driving a 08 G37s coupe
anyone have pics with this particular setup? or similar setups?
kind of nervous to pull the trigger with such aggresive offsets
http://www.vossenwheels.com/gallery/...VVSCV5_e16.jpg
Cleared the Akebono's just fine but recommend stretching a bit on the tire and trim the rear bumper bracket especially since the rear is a +25
I was on Stance Coilovers...But still if your going to pull the plug on Buying those with the +25 offset in the rear IMO you'll still need to shave that Bumper bracket...I was 24.75 off the ground to fender... I ran it pretty low... Worth it and it was my DD...
Being on springs you'll be fine with a tad of a poke but will look good IMO...
it's the bracket that get's everyone and all you hear is rubbing when you go up a drive or a corner real hard...Shaving the bracket is nothing and all I did was take a cutter and drilled a hole to put a small screw on to hold it...Diego from Vossen didn't do that and his held on just fine...I did it for I travel LA traffic! LOL
Now don't shun away thinking its a lot of work... Even the tire shop can shave them for you...it's about 1.5 in to shave off to bee a perfect fit not to rub the rear tires...
