Sticky Grippy Tires
Sticky Grippy Tires
Hey guys! Im looking into getting a new set of tires and i am lookin for some help! Im running 490rwhp and with the michellen pilot sport on there now i am not able to get all the power down. What do you guys recommend?
F245 30 35 R285 30 20 also anyother ideas that might help like traction bars ect? Thanks for your help Happy Holidays!
Hmm try some Bridgestone RE-11 or Toyo R888. If cost is a problem I say try the Toyo T1S but you might have the same problem. I'm not 100% sure. Also what are you alignment specs? Sometimes when you run alot of camber traction takes a hit.
I looked into the bridgestone re-11 seem perfect for me but sadly they dont make them for 20" rims or atleast not that i could find
I'm in the same boat as I get a lot of wheelspin with my twin turbo setup. What I've been trying to do is feather throttle and launch from 2nd if you are 6MT.
Other than that you can roll the fenders and get wider tires, preferably drag radilas for the track. On the street you have to settle for street tires and limited grip. Don't think you will get anything much better than michellin pilot sport unless you go to streetable slicks.
i want really wide tires up in the front 285/25/20 and 30/25/20 for the rear on vossen cv3 20x10.5/20x11 how would my steering be affected? this set will be different from the sticky tires also at this point the car will be on airride?
That's getting real aggressive up front and may require some fender mods
Also running on 25 series will be pretty rough, another 1/2" thinner at the sidewall compared to 30 series you'll certainly feel every road issue.
Hankook ventus rs3, Dunlop direzza zll.. If strictly taking it to the track to put power down new wheels and tires in 18s. Otherwise it's driver mod and learning your throttle.
mmnjtwa
Sep 7, 2015 02:27 PM
footballmania32
Sep 4, 2015 03:06 PM
