275 tire with 25mm spacer?
Old Nov 3, 2014 | 10:23 PM
Tiny's-G37s's Avatar
Tiny's-G37s
Has anyone or is there any way to fit 275 tires in the back with 25mm spacers? Is it gonna tuck in between the fender without pulling the fenders or going really negative camber? Maybe just cutting the bumper tabs? I do have a camber kit on right now and I'm lowered on eibach springs. I'm talking about the stock wheels here. I currently have the stock 245's with the 25mm spacers in the back and it looks sick and was thinking it would be even better with 275. And no, I don't want aftermarket wheels. Thanks in advance.
Old Nov 3, 2014 | 10:39 PM
Tiny's-G37s
Here's how it currently sits.
Old Nov 3, 2014 | 11:29 PM
You can run 275/35/19s, just remove the spacer, mount the new rim w/ 275s and see how much spacer you'd need to get the same fit you have now, I'm thinking 10 to 15mm should work.
Old Nov 5, 2014 | 03:08 PM
darrick's Avatar
darrick
My same thoughts ^^^
Old Jan 28, 2016 | 12:37 AM
Armando5642's Avatar
Armando5642
Hey man sick setup, what size spacers did you use on the fronts? And are you running stock tire size/ ride height?
Old Jan 28, 2016 | 11:08 AM
Redfire32's Avatar
Redfire32
Ginger ninja
I run 275/30/20's in the rear with 20mm spacers. I loved the look!!! So sweet. But after I lowered on swifts I had camber probs for real. Plus my rear tires were mere millimeters from rubbing the fender walls. I needed spacers to clear my BBK. But I had to switch to 5mm spacers to get enough play to get the rears aligned. Hope this helps.
helloandchau
Oct 6, 2015 05:26 PM
Steezus_g37
Sep 5, 2015 04:41 PM
Sylo
Sep 3, 2015 04:44 PM
