Going down to 18 from 19. Please Help
Old Jan 15, 2015 | 05:48 PM
gogetter's Avatar
gogetter
here are the pics of the 18's I used.... sorry it took so long..
Old Jan 27, 2015 | 04:30 PM
Tiramisu's Avatar
Tiramisu
I thought those particular OEM wheels wouldn't clear the Akebono's? Thought the wheel had to be at least 18x8.5 in order to clear the caliper. Have you had any issues so far with the set up? Have any pics of the entire car with these wheels on it?
Old Jan 27, 2015 | 08:27 PM
vqsmile's Avatar
vqsmile
If you're talking about gogetter, he said he used 18x8.5 all around AND a 10mm spacer on the front.
Originally Posted by gogetter
HI, I just did that same mod from 19 to 18x8.5 all around. The one big factor to consider is if the wheel will fit over your sport brake calipers. The Infiniti 18" I bought did not! I had to install a 10mm spacer for the front wheels only. Now I know why the bolt screwed in the rotor is for ... Just something to check BEFORE you buy new wheels....
Old Jan 28, 2015 | 05:19 PM
gogetter's Avatar
gogetter
Hi, Yes these wheels are 18x8.5 from the sport G35 model. They are the rear wheels. The ones I bought was from ebay and the seller was Allfactory. The wheels are reconditioned. The big problem I had is that going speeds between 60-80 I get a massive vibration on the steering wheel. Unfortunately once you mount rubber on the wheel. You cannot return them. They seem fine in the back since its not a sensitive. I tried to rotate the back wheels to the front and the front to the back. Still have the vibration. its OK if i'm only driving around town and not on the highway. Ive given up on going to 18's and going to go back to the 19's . I will probably sell the rears 9" width and go with the front 19x8.5 so at least I can rotate them and have all four tires the same.
Old Jan 28, 2015 | 05:25 PM
vqsmile's Avatar
vqsmile
Are you using a hubcentric spacer on the front? If not, that is most likely the cause of your vibration, which is also why your swapping the other rears didn't make any difference. The wheels aren't getting perfectly centered on the hubs, so instead of going around in a circle, they spin around in a slightly elliptical manner, resulting in the vibration.
.02
Old Jan 29, 2015 | 09:10 AM
gogetter's Avatar
gogetter
Yes i am using the hubcentric spacer. I will send a pic later when I get home.. Main point is watch out for Re conditioned wheels .. especially from Allfactory..
Old Jan 29, 2015 | 05:22 PM
gogetter's Avatar
gogetter
Here is a pick of the hubcentric spacer I used. To test out this set up. I put the original 19" on with the spacer installed and had no vibration issue. This proves that the Allfactory wheel is defective ..The 18" G35 sport "wish bone" i believe is the name of the wheel. Will work just as long as you get a known good wheel to use and the 10mm spacer.
Old Jan 29, 2015 | 05:29 PM
gogetter's Avatar
gogetter
pics of spacer
Attached Thumbnails Going down to 18 from 19. Please Help-cimg0001.jpg   Going down to 18 from 19. Please Help-cimg0003.jpg   Going down to 18 from 19. Please Help-cimg0004.jpg
Old Jan 29, 2015 | 10:18 PM
vqsmile's Avatar
vqsmile
I put the original 19" on with the spacer installed and had no vibration issue. This proves that the Allfactory wheel is defective ...
I would agree with you.
Old Jan 29, 2015 | 10:54 PM
Any chance you can return the bad wheel?
Old Feb 2, 2015 | 11:19 AM
gogetter's Avatar
gogetter
If anyone knows where I can get a GOOD wheel; like a take off or someone wanting to sell there wheels like above. let me know.. thanks guys..
Old Feb 2, 2015 | 02:34 PM
Post a WTB (want to buy) thread in the classifieds, you'd be surprised how many members have extra OEM stuff collecting dust.
Old Feb 2, 2015 | 02:54 PM
vqsmile's Avatar
vqsmile
** Speaking off topic for a moment. **
Brad this reminded me of something. It would be great if you had an old OEM 18" sport wheel around to see if it clears your Wilwood brakes. I'm dying to make an upgrade, but I don't want to have to add in the cost of new wheels too.
Old Feb 2, 2015 | 05:11 PM
  #29
There's quite a bit more clearance (depending on which Wilwood caliper you're wanting). Shoot me a PM w/ the caliper and I may be of help
Here's their bolt-on kit
Wilwood High-Performance Disc Brakes - 2009 Infiniti G37 4 Door, Except Brembo Brakes
And the front 6 pot radial mount caliper
http://www.wilwood.com/Images/Calipe...l_Mt-cm-lg.jpg
That caliper has more room than my Superlite 4 pot so I have little doubt it would fit behind those OEM 18s.
Old Feb 24, 2015 | 05:16 PM
  #30
Stanford Chiu's Avatar
Stanford Chiu
I went down to 18s for winter. After months of research, if you're staying within Infiniti/Nissan OEM wheels, only two will clear the Akebono BBK.
The G37xS wheels:
G37xS_2011.jpg Photo by spamb0t | Photobucket
And the 350z anniversary edition wheels (standard on later models):
http://rafalr.com/rims/350z/_wheels1.jpg
I went with the 350Z wheels. They fit perfect, you will need to get acorn lugs.
