Would Work vsxx fit g37 coupe with bbk
Hey guys wanted to know if these would fit with the akebono the wheels are work vsxx their offset is 19x9.5+19 and 19x11+19. They fit a g35 coupe with brembo bbk they are smaller he needed 10mm spacer to run these. Do you guys think they would the g37s.
The offsets seem to be okay. It depends on the look you're going for, and how low you'll be dropped. There's ton of info/pics on this forum.
You have to make sure the disk type is correct. For akebono, you need T-disk for the front and A-disk for the rear to avoid using spacers. You can also get away with R-disk fronts and O-disk rear by using an 8mm or bigger spacer in the rear. I'm not 100% sure about the spacer size for the fronts, but I'm almost positive a 5mm spacers will clear the caliper.
Any other disk type will require a much bigger spacer, and will basically be a waste of lip size. I'm on my second set of VSXX. Originally had a set on my g35 coupe and now with my g37 sedan with Akebono.
superjoey
31
Mar 22, 2023 11:56 PM
warpeacelove
Oct 28, 2015 02:59 AM
