Brakes aren't touchy
Old Aug 11, 2014 | 01:21 PM
cksigurd's Avatar
cksigurd
I recently bought a used '08 coupe (Journey) and I really want to get better stopping power and not have to put so much weight on the pedal just to stop at a light.
Everything is OEM and a friend told me to look into StopTech brake kits but I don't know much about the G's brakes to make an informed decision.
What do you guys think? Is this normal? Could it be a simple solution such as replacing the brake pads? And/or what would you recommend for a kit?
ps. I've bled the lines and ABS multiple times at a shop, had them inspect everything, and everything looks fine.
Old Aug 11, 2014 | 08:47 PM
If you've got old OEM-type pads upgrading to a better biting pad such as Stoptech Street Performance Pads should make a nice difference. They will leave more dust but IMO it's a small price to pay for the improved bite. Just be sure to bed them properly when you get them. Also you said you bled the lines several times, I'd go for a complete fluid flush w/ new Dot4 fluid, even freshly bled brakes won't stop real well if most of the fluid is old.
Old Aug 12, 2014 | 01:19 AM
speedracer g37's Avatar
speedracer g37
doesn't sound right. shouldn't take much to get the car to stop at a light.
Old Aug 12, 2014 | 12:49 PM
cksigurd's Avatar
cksigurd
Nice advice, thanks! I'll definitely look into it.
Old Aug 12, 2014 | 01:48 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
If it's an 08, then you're beyond the 5 year max recommended life for brake fluid. Even if the car was taken off the factory floor and put in storage for 6 years, you'll still need new brake fluid. Brake Fluid is hygroscopic, and absorbs water, which ruins your braking ability over time.
Flush out for quality fluid.
Mattimus
Oct 4, 2015 01:33 PM
Bennyjoel
Sep 30, 2015 11:56 PM
Soccer4555
Sep 30, 2015 05:31 PM
VIVID
Sep 27, 2015 09:45 AM
